So I imagine that the original issue was that the rings were never bedded in correctly?
I suppose this is testament which proves the "get load on the engine ASAP" run in method.
What run in method was originally used?
Glad to hear you have it under control!
I'll be interested to see how mine goes if/when I get down to Collie, venting the sump seems to make all the difference
I think nearly everyone will be - if only because I can now stop sulking about it.
Possibly to probably. Certainly the original engine had far too much blowby which is usually an assembly issue and given the workshop who built it specced it, installed it, fired it up and ran it in - if it wasnt an assembly issue then it is/was still their issue. By the time I got to confirming how it was all done I was so far over talking the said workshop and generally dealing with their &^%$ I never did ask.
For what it is worth having spoken to a number of other engine builders and to Pacific Engine Parts themselves the CRC + drive it on start up (ie dont let it sit at idle) is the way I would be doing all engines in the future.
Also for wha it is worth I rechecked on the oil return diameters in the old block. They are 8mm which is slightly larger than the head. The head got drilled to match the block - which is porbably a mm or so smaller than most people do. Anyway those five returns probably add up to well under half of the total return area.
Edited by djr81
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
