This is a genuine real McCoy V8 supercar. "Supertaxi" is a slang term used for them.
The suspension in this car is a Morrison live axle 10inch rear diff, GRM build 4 link with watts linkage in the rear
Front is a Paul Morris designed and Paris ascot built wishbone suspension using racer industries upper arms and ascot fabricated lowers.
Rear shocks are ohlins and front shocks are sach. The ohlins are in the rear as they are original GRM. The car started as a strut front end in 2001 and ohlins don't do a conventional shock to suit this setup so Paris used the sach coil over instead.
Awesome thanks mate. Keep up the updates very interested in this
Hopefully this coming week someone at the shop will find time to clean out the inside and get the engine back in.
We've been flat out with customers vehicles recently so haven't had a lot of free time.
Justin at pro wire is going to begin wiring the car next week, the old loom was a mess so a new loom and PDM is being installed.
I've got new windows being cut for it at the moment and Nacca ducts ready to go in.
The diff has been overhauled by diff technics and is right to go now.
  • 2 months later...
So I was able to spend some time on the car today.
New fuel pumps ready to drop in. These are believe it or not straight off the shelf Supercharged VT commodore fuel pumps. Nothing special. They are lifed at 12 month intervals.
The fuel tank houses the pumps inside this cavity which is trap doored
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
