This engine is from a 1998 nissan stagea rs4 auto its an rb25det neo 4wd it has 180000kms
Head gasket was changed at 110000 and head was serviced (i overheated it)
I overheated it again at 180000 when the radiator gave way but shut it down to late and spun a main bearing (knocking in the bottom end)
All parts there good for project engine alternator, ac,turbo , inlet manifold ,exhaust manifold, and heaps more
$650 neg cash must pick up from gladesville
email me [email protected]
what condition is the head? or os it beyond salvageable? warped or cracked?
hi mate, i have bought this car from adam and am looking to sell the engine etc so flick me a pm
im located in western sydney (lower blue mountains)
pete
sorry about the late reply i dont check sau much the head should be fine but it is still on the engine so i am not 100% sure on the cond but when it was taken off the first time it was good and i had it crack tested and valves done and everything was tested and the guys at thornleigh cylinder heads said it was all great so we put a new head gasket arp studs and all ned timing belt,seals,waterpump,and the rest and everything was running great until the radator gave way and it the engine got to hot again. Pm me if anyone needs more info so i get an email direct to my phone just quicker thanks
  • 2 months later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
