Hi, just a few thubgs for sale. Any question please PM, I will try to check everyday.
90amp RB alterntor needs new reg $10
90amp RB altenator work but drops is voltage after a long drive $20
RB20 early manual ecu working just replaced with a chipped one$60
RB20 ignitor tested and working $50
gtr stock water cooled oil cooler $30
rear gtr wheel bearing brand new i bought to fix a problem that didnt exist $50
cat back hks drager looks like one flange has been repaired replaced with qieter usystem$120
gts4 gearbox and transfer case. Crunch in fourth otherwise works well and is quiet replaced with a 33gtr box $150
stainless front pipe with seperate return screamer pipe some new zealand brand (one bolt to turbo wont fit so you need to use a different size bolt) put the original one back on $50
parts located in south east and west melbourne. Offer if you thibk price unreasonable. Pics on request thanks
Edited by RIPae86
https://www.sau.com.au/forums/topic/417061-vic-cheap-spares-r32-gts4/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
