Hey everyone,
Bought myself a "dash cam", It's a small camera that is quite nicely hidden behind the rear view mirror to capture the drive ahead.
The problem i have is that i can't think of a good way to make the power cable for it tidy and out of site, The cable just goes to from Mini USB to the cigarette lighter.
Is there anyone that has an idea of how i could do this? Possibly running the cable along or under trim to get towards the cigarette lighter?
Had a look to see if anyone has written up anything about it before with no luck, Any help would be great!
Car is a 2000 R34GTT Coupe, as a note if it helps... it has a stock sunroof and the stock triple gauge cluster above the A/C.
I tucked mine under the head liner and then in the A pillar trim then between the dash and door seal, then behind the glove box to the cig lighter. I'm planning on wiring a new lighter port in behind the dash to plug it into.
Yeah i think that will be my first option, if i can tuck the wires neatly enough under the head liner and trim i'll just leave it like that.
Does the wire stay under the head liner without any adhesives or clips/ties?
Generally it'll stay in the liner if you give it a good tuck in the wedges, did this for my gps in my old car and was stuck in forever.
I've been looking for a dash cam too, mind linking me the one you got?
Got a GS1000 model off ebay.
Exact one i bought: http://www.ebay.com.au/itm/GS1000-Camera-Car-DVR-HD-1080P-30FPS-Built-in-GPS-G-sensor-IR-LED-Night-Visin-/251128301500?pt=LH_DefaultDomain_0&hash=item3a7869c7bc&_uhb=1#ht_6727wt_1148
Full HD 1080p 30fps, read a lot on the Whirpool forums about it. (good camera thats better than the cheaper entry level ones)
Whirlpool Thread http://forums.whirlpool.net.au/archive/1952995
Website with a shitload of good reviews and examples http://dashcamtalk.com
Hey everyone,
Easy
Pull the screws out of sun visor hold clip
Pull screws out of visor
Now the headliner will be loose enough to push wires under from the front but use a tiny bit of duct tape or gaffer tape to tape down under headliner away from copper tube in front of the sunroof ( its a roof heater to keep ice off sunroof and flinging it off at speed do not break open or drill thru it)the tape will keep wires from walking around under your screws too , so you dont screw thru wires
Undo the a pillar molding -gentle!!!! Or you will break it or clips
slide loose from door arch trim
Remove the rubber around front of door on car
Now you have a path for the wiring down to fuse box or to cig lighter
you can hardwire to switched 12v with a 1 amp fuse you just need to figure out polarity of the factory cig plug , unscrew it and trace the fuse solder joint Note which wire it is , marked or not
The fuse wire is positive
The twin metal tabs ground
You're a legend Troy! that's exactly what i was looking for actually, i never knew about that copper pipe! very interesting.
With the pillar moulding, It's just clipped in and has no screws? So i just need to be careful when prying it away?
Cheers
Cheers
The A pillars are brittle and most are broken already
Use a plastic or wooden panel popper tool if you have one , or a thin plastic or wooden spatula / bog spreader/ putty knife or worse case a old butter knife slid into the small gap by the bend , your trying to put tension on the middle of the panel vertical and walk it around slowly towards the back of the car,( which has two little hook hoop catches on the end holding it by your head
Gently moving it open they pop out leave the lower front till last
Once you start working the front lower half its final holding part is a hoop of plastic on the very end ,
two hands and some flex will pop it free without breaking ( the little white clips on the back check for all of them and if missing replace for a few bucks) also superglue any broken black holders now ( ca model glue from hobby shop works best)
Dont bend the rubber molding in the door ( skylines worse feature ! damn doors that wont stay open )its $$$$ and will cause water / wind wistles/ fumes to enter
the sunroof model has a butt load of room hidden behind the center sunroof switch plate , mine has a tv and gauges embedded in the area in carbon surround now !! Haha
Use care fixing wires by pedals if you go to cig lighter power nothing worse to deal with while driving
Haha sweet, Thanks so much for your advice dude, I haven't got a panel popper tool but do have similar tools that i can use. Also have some model glue (from when i used to make model planes and cars) so i think i'm all set!
Your set up sounds swish, do you have pics on the forum somewhere?
No current ones of the inside or out
Performance auto and sound mag in north america had it in readers rides issue and it was tuner of the week last year
Car of the year for SAU-SA first year
Its undergoing major mods with new upgraded gear , carbon kevlar body kit , some suspension and engine mods just in time for repaint haha
its being documented for a feature car shot in magazine , pointless to post photos now everyday just about something changes lol
Plush black carpet and racing seats and lots more today
Edited by Carbon 34
Sounds amazing mate, look forward to seeing photos some day
Thanks again for the help!
Premod exterior photos from tuner of the week
http://www.pasmag.com/features/reader-rides-from-your-garage-to-ours/2135-tuner-of-the-week-troy-edmonds
Absolutely immaculate car dude, photos are amazing!
Great example of a white 34
Thanks I took those with my old camera 10mp sony alpha
New 25mp more better haha
Will post the build up after done and edited
It includes many how too's and why's
Car wont even look close to that except white still
whoops, just noted the article says Polar White! nevermind!
Lol its most likely going to be painted another white absolute pure with white epoxy primer
That creates a blueish purple hue in street lights at night , almost a colour flip but no pearl its the light spectrum refraction ( my old rx7 was painted a variation of that ,it works )
I love the storm trooper look but carbon attracts the police around here, so sadly those body parts will get paint
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
