I have decided to sell my project car as i want to buy a R34 GT-R.
The engine and gearbox are currently out of the car. The turbo's and manifold have already been sold of separately.
Car has rego till mid year 2013, RWC can be arranged at your own cost by my mechanic.
1994 R32 GT-R
Block:
Block Balanced
Crank Tested
Acid Dipped
Blue Printed
CP Forged Pistons
Eagle Forged Rods
Heads:
R34 GT-R Head
Rebuilt/Cleaned
ARP Head Bolts
3-Layer Copper Head Gasket
Cams:
HKS 264 step 1 Cams
ISC Cam Gears
Fueling:
Bosch 850cc Injectors
Stock Fuel Rail
Nismo Fuel Reg
Bosch 040 Internal Fuel Pump
Oil Mods:
Trust Oil Cooler
Custom Oil Catch Can
Baffled Sump
N1 Oil Pump
N1 Water Pump
Induction:
HKS 4inch FMIC
Aftermarket 3.1 inch Front Pipes (unsure of brand)
Custom made 3.5 inch Cat-Back
JUN BL Muffler With 4inch Tip
Suspension Mods:
Tein Coilovers
Cusco Adj. Caster Rods
Whiteline Sway bar's Front & Rear
JIC Upper Adj. Camber Arms
ISC Hicas Lock Bar
Braking:
AP Racing 4 Spot Front Brakes
Brembo 2 Spot Rear Brakes
Endless Brake Pads
Slotted Rotors
Braided Brake Lines
Electronics:
Haltech PRO Platinum ECU
Blitz EBC
Misc:
Work XD9 Wheels 18x10 + 18 With 265's On All Four
N1 Front Bar + Snorkels
N1 Side Pods
N1 Bonnet Lip
N1 Rear Boot Lip
N1 Head Lights
OEM Indicators
Clear Side Indicators
Custom Leather Seats
Carbon Fibre Interior
Blitz Gauges
Kenwood Head Unit
Speakers
Alpine Type RSubwoofer
Amp
R33 GT-R Gearbox
Car had good compression results showing 170psi on all banks.
With the correct turbo setup you can have yourself a potential 10second car with its current engine setup.
The body is in amazing conditon for the age of this car. Car looks great and sounds tough. Received alot of head turns and compliments when i drove this thing around town.
Iam asking $25,000 as is (Engine+Gearbox+Car) Iam slightly ono with the price.
Or i can throw in a T51R turbo kit into the mix aswell.
T51R SPL BB turbo hiflowed to T62 spec (108mm)
HKS Manifold
HKS 60mm Wastegate
HKS Fuel Rail (Brand New)
HKS Cam Gears (Brand New)
HKS Step 2 Valve Springs (Brand New)
The price will be 30K Firm if i include the T51R kit.
Car has original log books from Japan and owners manual.
Car can be viewed at Edge Motorworks they open up on the 7th of this month.
WANT CASH, MONEY, $$$ ONLY. NOT INTERESTED IN SWAPS. IF YOU CANT AFFORD THIS CAR DONT LOW BALL ME.
Edited by Tyranus
https://www.sau.com.au/forums/topic/417075-94-r32-gt-r-incomplete-project/
All PM's replied.
Forgot to mention that the car was making 350kw on all paws at 18psi (-5's) the car has also been featured on Motive DVD 12.
Edited by Tyranus
  • 4 weeks later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
