For Sale
My 1996 Nissan R33 GT-R LM Limited V-Spec Series 2.
1 of only 98 produced by Nissan and launched in May 1996 to celebrate Nissan’s participation in the Le Mans 24 Hours in 1995 and 1996.
Imported from Japan in December 2008 in original factory trim with 62,299km’s on the clock, vehicle has now done 77,177km’s and has had one mature owner since arriving in Australia.
The vehicle has been carefully and tastefully modified and has always been garaged. The car has been tuned by ESP Racing in Queanbeyan and last made a conservative power figure of just under 300KW on the ESP 4wd dyno.
Engine
  • 2.6L RB26DETT Twin Turbo Straight 6
  • HKS GT-SS turbochargers
  • HKS Intercooler Hard Pipe Kit
  • Nismo Fuel Pump
  • Nismo Fuel Pressure Regulator
  • Nismo 600cc Injectors
  • K&N Panel Filter
  • JJR Adjustable Cam gears
  • Trust Clear Timing Cover
  • Oil/Air separator
  • Apexi Power FC Computer with Hand Controller
  • Splitfire Coil Packs
  • Fujitsubo Legalis Super R Cat Back Exhaust
  • Catco High Flow Catalytic Converter
  • JJR Stainless Front Pipes
  • Cooling Pro Alloy Radiator
  • Gates Racing Radiator Hoses
  • Cooling Pro Silicon Engine Hose Kit
  • Greddy Oil Filter Relocation Kit
  • Greddy Oil Cap
  • Stainless Fuse Box & Washer Bottle Covers
  • Engine Earth Grounding Kit
  • Greddy Carbon Air Diversion Plate
Exterior
  • Work Meister S1 18” x 9.5” Wheels
  • Federal 595 RS-R 265/35 ZR18 Tyres
  • Eibach Coils
  • Bilstein PSS9 Height & Damping Adjustable Coilovers
  • Whiteline Heavy Duty Blade Adjustable Sway Bars
  • Nismo Tinted Side Indicators
  • Tein Bonnet Dampers
Interior
  • Impul 300Kph Instrument Cluster
  • HKS Kansai Electronic Torque Split Controller
  • Greddy Profec B Spec II Electronic Boost Controller
  • Greddy Full Auto Turbo Timer
  • STRI DSD-CS Boost Gauge
  • Nismo Gear Knob
  • Custom Leather Gear Boot/Handbrake Boot/Console Lid
  • Kenwood CD Tuner with front USB input and IPod Control
  • Kenwood Rear Speakers mounted in custom rear shelf
  • Security/GPS Tracking System
Limited Edition factory fitted extras
  • Champion Blue duco (code BT2)
  • Carbon Fibre Rear Wing
  • N1 Front Ducts
  • N1 Bonnet Lip
  • Commemorative GT-R Decals on C-Pillars
The duco has a couple of minor scratches and stone chips as you would expect on a car of this age, and the rear side window tint has a small tear.
The vehicle is located in Canberra ACT.
The price of this vehicle is $29,900. Serious buyers only please, no offers at this stage thanks.
  • Payment by Cash or Bank Cheque only
  • No overseas buyers
  • No buyers purchasing on behalf of someone else
  • No trades or swaps
  • No test pilots
Please PM me (John) with any questions or to arrange an inspection. At the moment this is the only place the car is advertised as I am hoping to pass it on to a true enthusiast who appreciates such a rare vehicle and that will look after it as I have done.
More pictures are available on request.
Edited by JD_R33
Hey John, congrats on a beautifully looked after vehicle. Sorry, maybe a dumb question, but can you tell me is the GT- R LM RWD or AWD? :excl:
Cheers
would love it and a fair price but still out of reach, im at the other end of the market hah.
goodluck mate,
you seem like a real genuine seller with a great car so shouldnt take long.
Car is now sold. :sweat:
It has gone to a new home where it will be well looked after.
Thank you to everybody who took the time to enquire about it, and left comments on here.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
