Okay guys, Just got myself a Turbosmart Boost Tee and upped the boost on a stock R33 GTST Sedan to about 10psi. It then started misfiring so I went out and got myself some NGK coppers 0.8mm put them in and then went for a run, at first I ran at 7psi, no misfires runs fine some popping of exhaust. then 8psi, no misfires runs fine and no popping of exhaust...., then 9psi no misfires runs really well no exhaust popping, and then 10 psi, misfire galore... and popping exhaust galore.... I checked the coil packs when they were out, and there seemed to be no hairline fractures I could see.... THen again I didn't them examine using a microscope but with my eyes, they seemed fine, gave them a give wipe down and sprayed out the boot area.
So what seems to be the problem? anyone?
https://www.sau.com.au/forums/topic/417110-boosting-misfires-and-pops/
Totes agreed, I have 5 yellow jackets and 1 new looking OEM coilpack. I wonder why for a while, then realised they might have died and the previous owner dropped in an OEM coilpack.
Car now is starting to develop a slight misfire on days at 0.8bar, I'm blaming those ling long coilpacks
please tell me you arent running stock ecu?
your probably hitting the stock rich and retard if its still the stock ecu
its also likely your coilpacks are dying on boost which is pretty common
but before you go and shell out for coilpacks check what ecu you are using
you cant just crank up the boost and hope it will work on the stock ecu
We weren't going to mention R&R to this guy. Pops and misfires are different anyway. Once he had bought new coils and managed to get it to run at 10 psi without misfiring but started wondering why it was blowing black smoke and going slower than before.....THEN we would have told him about R&R.
Yea I have realised it's running R&R, going to get an ECU before I up the boost more. It's actually running quite nicely on 9psi at the moment, no problems, not even black smoke or sluggish. But before I do anything I need to deal with a speeding fine that should be coming round anytime now... Hopefully it wont hit hard...
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
