Got a pretty clean 93 GTR that has bugger all done to it,so far. Had it for about 25,000k`s now. Just the other week i notice this grinding or rattling noise coming from what sounds like the bell-housing on an up hill take off in 1st. Noise only hangs around for 2 seconds or so. Just had it taken from 180 to 220 awkw around the same time. Noise only happens 2-3 times a drive (long drive) on easy take off. Won`t ever happen if take power up on the clutch first. Ayone out there gone through this??
Might be similar to what i have, which I'm guessing is rooted input shaft bearing in the gearbox. I've been driving with it that way for years now (but no launches). I'll get the box rebuilt the next time i take it out.
Check the oil level as a precaution.
Carcass? "Death is no escaaaaaaaaape..."
Well Adam or 'Mr Stabby' I hope it doesn't come to a gear box re-build $$$. Not before clutch time anyways. Can't feel a thing through the stick though. Went for a blast today and not a thing,so i guess the noise will become more and more consistant with wear? Don't launch it anyways. Still feels like a stock clutch,light as a feather. It all happens while i'm Descanting The Insalubrious.
    • To clarify what I posted above, I though you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
