  • Replies 62
Hi, Everyone
Putting up some of the wheels and tyres I used for compliance and RWC,
GTR33 OEM forged wheels 17x9+30 with Falken Azenis 255/40/17 90% thread $1400 ono
GTT34 Oem wheel with Nankang 235/45/17 95% thread $800
GTR34 OEM 18x9+30 with Dunlop Sport 3000 95% thread $ 1800
S15 Buddy Club P1 Racing 17x8+32 same all four ,no tyres $900 ono
They may be chosen to go with the 4 GTR33 I am seeling ,see whole car for sell thread.
Wheels can fit other 5x114.3 PCD models.Can try fit in Melbourne Braeside 3195.Interstate buyer will have to pay freight
cheers
Alex 0439878905
Pm ed Alfie re pair of GTR33 head lights in great condition $600 for you to pick up
Also putting up a set of brand new after market LED tail lights for GTR and GTT34 $300
Hi,all
Selling the following custom plates for Victoria, cost you nothing to keep.All White letters on black plate
MY NUR $1000
S1LV1A $1000
N1GTR $1000
A350Z $1000
R34GTT $1000
VEIL-33 $800
CHEUNG $20,000
AC-111 $800
CITX $400
NATO88 $400
also advertised elsewhere and will go on e-bay
Also advertised elsewhere
Need room for more track cars
95 GTST R33 silver no reg, no defect, no gear box,no exhaust, front bar and bonnet , comes with coilovers, after market 17" wheels good tyres, split dump,good running engine, no time to part out, sell whole car for $3800 ono
180sx manual, no reg, no VIV,no front bar and left front guard, damaged wheel arch , use the engine for another car,big bore exhaust, after market big wheels. has no time to part out, sell whole car for $2200 ono
for more details pls call/sms 0433878905
pic file too big to upload will resize it asap
Can supply RB25 gear box in excellent condition and 400R style front bar for GTST R33 with reo at extra. exhaust is a very good one 3.5 inch now goes with the car
180sx on hold, may end up with the wrecker for parts, don't have time to part it out myself.only missing engine and front bar + left hand front guard.Non VIV
  • 3 weeks later...
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
