He said something about being in the bahamas.......and thanks Snowy;)
What was the cost of the parts mate. Just contemplating the possibulities later on (or taking advantage of someone who busts a gearbox and sells it)
They are definitely not the same
neither will the new holden 6 speed.
Getrag is a brand not a model, remember that.
as for parts. a 6 speed sequential box from hollinger would only cost you a little more... while a gear set will cost you alot less
The R34 gtr uses a V160/161 getrag transmission.....as does the JZA80 supra(and i assume that this tranny is used by a number of other vehicles) ....therfore the internals are IDENTICAL....there are two types of synchro's some have 6 tooth and some have 7 tooth....you dont know what you got until you pull it apart.....the gears are about 500 each and the synchro ring vary from 70-120 each....the shift drums are 280 each
heres a pic of the new gear.......the arrow point to the teeth that snowie likes to destroy.....these are the dogs....the shift drum locates on these and locks the gear to the shaft when selected(the synchros job is to "synchronise"these 2 componants by acting as a brakepad for the gear(it rides in between these two parts)....these little teeth transfer all the power!Its quite unbeleivable
I am in the automotive trade....lots of my friends have panelshops/mechanical repair shops both here and in japan...i usually get called in for one off jobs,jobs that require attention to detail or jobs that require a bit of engineering/design for componants that have been damaged,failed/have a design fault or are no longer available so therefore have to make the part in question,basically all the ball breaking jobs :cheers:.......sometimes i am asked to fix the unfixable...i usually do something starting with the letter "F" to it and it aint fix :)
I think    The  WHITEs  that came 2 outright in Targa Tas   in there GTR   made  there own syncros ...  you can Not buy all the parts in a BMW Getrag 6 speed as they only list certain parts in the box 4 sale .. other wise a exchange box from Bmw  ..   Getrag rate there boxes  as the Maximum  inputshaft torque in  newton meters  the box can take safely  .. So not all Gearboxs with the Name Getrag are the Same ..
If they made their own synchros and they were ina ny way different to the factory ones, they should be disqualified.
Oh, they were.
on another note.....its not a power rating issue with this particular gearbox....its the fact of getting it into gear in the correct manor thats the problem
hahahaha has snowey been a bit rough with it?
:cheers: i think we all have been a bit rough with our 34GTR gearbox's....Its quite funny actually i had a 400rwkw supra at my place for a while that had this gearbox in it and the thing is still going to this day without drama's
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
