Hey guys,
I've had my 2001 V35 250GT off the road for a bit over a year now and it's come time to get it re-registered and back in action! :)
What I'm wondering is if you have any recommendations for workshops to deal with in SE Melbourne, as the one I was dealing with in Oakleigh South was a joke... He was finding problems that didn't exist and then delaying trying to source parts that even I could find. I think it was more he didn't do well with imports.
Given there's places like SSV near me, I figure there has to be some guys around here that know what they're doing and would appreciate recommendations!
Thanks guys.
Unfortunately, since the new regulations came in September last year, RWC's are very very hard to get.
I had a nightmare of a time trying to get one on my MPS a few months ago. They pinged it for 5mm too low (measuring at the mud bottom of the mud flap!), sand blasted windscreen (on a 3yr old car), four tyres, missing rear wiper.....etc etc. I took it around to a few places with the work order in hand, and they basically all said they can't let those things slide. Had to get all the work done, and then go for another run at RWC. It's a hassle. Now you have learnt why you don't let your rego lapse!
What sort of things are they picking it up for?
oh don't get me wrong - the good ol days I was getting cars that were clearly unroadworthy signed off. I even had one of the ol' 'money in the envelope with your rego and VIN' and they posted a RWC back to me.
But they're trying to clamp down on that - there are about 1/4 of the rwc testing licenses in operation now, and the guys who hold them don't want to risk lose them. everything has to be photographed and documented and uploaded to vic roads database......there are just no loop holes to let things slide anymore.
However back to OP - make sure you let them know that you own the car, and don't intend to sell it. They will be much more leninet if they know the car is staying in your posession because there is less risk of recourse against them.
No offense but what did you expect if the car needed a windscreen, tyres and was missing a rear wiper? Fair enough the height due to mud flaps is annoying but your car is either in a rwc condition or its not, a windscreen is almost always a must if it hasnt been replaced before.
The new rules haven't made it that much tighter, it still depends on who you take the car to and if they know or trust you, why would someone risk there rwc license if your selling your car to a random, there not gonna let stuff slid just to save you a few bucks.
Very true, in Mackay there has been a couple of them shut down. 1 of them in particular because he was a rip off f*ckwit and probably went out of business but that's a different story.
The guy that does our roadworthies does not "dodge" them if your selling the car for the exact reason Paul mentioned. But little things he will let slide.
I remember when a mate of a mate used to work in a dodgey shop in Bankstown. All it took was a call with VIN, Chassis and Rego and then duck by in the arvo with a case of beer and it's all good.
Gone are those days... :(
It's a shame that massive bombs are still around on the road though.
In QLD, you only need a RWC when selling or registering an unregistered vehicle.
I know that in Sydney, you'd need one practically every year. What's it like in Melbourne?
No offense taken - but the windscreen didn't have a single chip in it, and when i asked the guy to explain to me the laws about what constituted sand blasting he tried to feed me some B/S about 'dots per square cm' - while the next guy told me it was entirely up to the discretion of the tester as to whether it impaired vision or not (which he subsequently then passed the screen). My tyres were 2mm above the wear indicators, which apparantly is no longer a pass - begs the question what the wear indicators are for in the first place - but so be it - 4 new Pirellis for the new owner. And as for the mud flaps, i offered to rip them off then and there if it meant passing the car - to which i was told 'no, they are part of the car, the car was designed to have these fitted, they can't be removed'. Turned out the previous owner had fitted an incorrect profile tyre, so I put the correct size on and 'boom' - car was legal. But seriously - 5mm too low?
My point being that a lot of the grey area rules are now being defaulted to the strictest interpretation of the law due to the higher visibility on the testing process.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
