My current set up is a 04 350GT with Bose and NAV system. The previous owner has somehow put a AXIS DVD player in the cubby that I assume the stock nav unit sits ( the stock nav unit is tucked up under the dash.
This has USB/ DVD and Is rigged up to the Aux in on the screen. It works fine when stopped so I can use the remote to look at the track folders on the USB which works fine. But as soon as I start moving the speed sensor and handbrake earth cut out just the video feed.
I tried following this walk through to no avail
http://www.coderetard.com/2008/05/08/how-to-bypass-video-on-a-2008-g35/
Also looked up the service manual which says the speed wire should be white with a green strip, but I was unable to find a wire that colour on either the radio or the Nav unit.
I want to get this sorted especially since I wasted a few hours and manged to put a giant scratch in the middle of my radio on the gear knob and didnt even achieve anything so massively annoyed atm
Searched heaps but fund nothing else. Anyone done this ?
I believe it can be done by the Xanavi guys during the English translation.
Otherwise, read this post (& ones following) for hard wired approach.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
