Dyno Day
k_d
 Share
  • Replies 120
Yeah I had imagined that they would be happy to do it, however a few people have pmd me and said they would prefer ESP (for what reason i dont know/care, its nothing to do with me and none of my business!). Im not fussed personally but i think there would be more people turning up if it was at esp. If someone is unhappy with this they are more than welcome to dicuss their own dyno day/time with whoever they want, however the one that Kat and myself are organizing will be held at ESP and i will confirm a date on saturday.
Sorry if am coming across as a dickhead, i just want people to understand that we are trying to keep the majority happy and getting as many people as possible to turn up.
If your at ultimate tunes tomorrow arvo ill be there (its between where i work and park so i dont have a choice lol!), feel free to discuss it with me then
Agree with you.
Happy for Shell to have my posts deleted re ECu to clean thread up.
I think this thread is already too far gone and can be left as it is for the sorting out/planning...... when a definite date and location is locked in, another thread can be started calling for entrants.
I think I will have a car put back together (and hopefully still running).
I don't mind where and since I'm not organising it, it doesn't matter. If I had an issue with the organised location, I probably just wouldn't go.
I'm also curious to know how much cheaper Ultimate tunes would be. Last time we had a dyno day there, it was $50 each for two power runs (which I don't really consider cheap).
if you wanted to "segment" the day perhaps stick with a Japanese car theme. That said thats gay so invite the world :P nothing better than seeing little bangers struggle to reach 50kws and then some crazy nutter hit 500+kws in the same day.
I would anticipate getting 3-4 supras on board if we're lucky.
couple big blown v8s would be cool too!
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
