Fresh Forged SAMMUT built RB30 300kw+ capable setup
Full new motorsport prepped (heat and rub proofed) loom with all new connectors on every connection like CAS and injectors etc...
New Top end haltech PS2000 with latest firware etc and tuned by SAMMUT racing.
All new sensors and Ignition leads
New GT3582R
New 6Boost low mount manifold
New Plazmaman intake and TB
New HD clutch and 5 speed gearbox.
Complete setup for sale bolt in conversion, all only done run in kms on dyno. $4k for the LOT... cheap as!
Was built for circuit duties. We have just bought the car and the driveline is not needed as its going TT lS1.
SAMMUT had the fasted outright and the fastest steel 6 cylinder (Rb) in the world (300ZX)
that is insanely priced....
should sell in a heart beat.
I am assuming the ECU is already tuned and the new owner just needs to install and rock on?
literally bolt it in and drive, im putting it on the dyno today to check AFR and timing.... im sure nothing will be amiss as they build and tune 6 sec RB'S
Post the sheet if possible as I'm checking interest with a couple of mates currently.
Its priced too well to let slip.
Quick question, will this drop straight into a 32 GTR?
it will but this is a single cam.
Hi trent i emailed you before can you please give me a call or email me your phone number?
cheers
i may need the ecu so pricing has changed. i may strip it all apart and sell separate. Ive found too many goodies to sell for 4000.
5k for the full shebang or im going to strip it.
5k also includes brand new Di Philippo turbo back exhaust.
no.
wiring loom will be different.
engine mounts will need mods.
awd sup will require adaptor.
turbo manifold might not fit.
Still interested. Please call me 0418 657 612
    • I clean my wheels every time I was the car, I also clean the barrels, the only product I use on the wheels is truck wash, followed by wash and wax, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, there also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
