hey guys, im getting flood control on a desktop.
also when i post and actually hit the post button it does nothing. i have to refresh the page to see it. this has caused a couple of double posts.
also it has unfollowed me from whoretown, and wont let me follow again.
ill get into the mobile (iphail) issues after if you need them.
https://www.sau.com.au/forums/topic/417244-couple-of-errors-guys/
i have signed out of mobile (safari) and desktop (firefox) and resigned in. was thinking it had got confused and thought i was logged in mobile. hence the flood control.
no joy. still doing it.
Flood control is normal for users that are not club members, or SAU Donators
If the post button isn't working, I'd suggest a browser update or check add-ons (some add-ons to Firefox for example will break IPB).
Try now and see.
If not list browser, add-ons etc. It's working fine for me in FF and Chrome so yea... Usually a local issue
But yes, flood control should be removed for anyone with a member tag. (you've had yours removed recently Plattsy, so that explains that).
  • 4 weeks later...
  • 3 weeks later...
After the new maintenance, Spy has stopped, all threads appear as unread, and on my mobile (android) it's permanently in mobile version (which I hate).
can't change it by resetting defaults or clicking on the full version option. :/
on the up side. Gallery works. :yes:
The search function doesn't seems to be working 100% either, its returning lot less results.
Hmmm, will check that out.
Spy should be ok now - I had to enable the forums as a 'data source' - it was just watching the Garage before.
I tried to add a second Mobile skin which failed, I'm wondering if maybe this broke something, so I have removed the failed one. Ash was saying that mobile was working well.
I have exactly the same problem, but using IPhone. Can't edit any posts using mobile version. Pls help.
Try again? Might need to log out and back in.
The ads are comming up terrible aswell sometimes, either they are appearing over text and wont go away or they are taking up quater of a page. Using IE
Can you show me some screen shots? I'm on a Mac so really difficult to test all the browsers. :(
Logged out and signed back in. Can edit now.
Being trying to click on full version and nothing happens. I highly doubt I'm the only one experiencing this.
Edited by Ants
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
