BTW - switched to a new mobile skin now. Works well.
Also put the skin in the 'Change Theme' drop box so you can go back to it if you switch to full version.
Still cannot use full version via mobile (iPhone)
all good prank. my notifications stil say the same thing. also not able to follow whoretown (bob) or the lulz thread still.
Can you screen shot the notifications? Can't reproduce it anywhere. :(
then this is what i get when i click on said notification.
Im getting the same problem on a few of the threads i am following.
It looks like all of the old threads i was following are good, its the newer ones that i am having trouble with.
Sorry if I've missed it guys, been reading through the latest threads here but haven't seen it mentioned.
What's going in with video embedding? Using my mobile (Android), I can't see embedded videos using either the Full Version or the Mobile Version of the site. Posts containing an embedded video are just big blank empty posts.
quick heads up if it hasn't been reported already, subscribed to a few forums and instead of nbsp tags they get replaced with &#160 tags which shows up in email programs for windows and android.
So on the website it's self it looks fine, however the email version gets a bit annoying to read.
eg. http://www.skylinesaustralia.com/forums/topic/420345-for-sale-clean-out-cheap/#entry6760663
what it actually looks like in mail version:
"hey have few parts that i wanna get rid of been sitting around for
awhile
brand new never used GFB BOV still in box $200 brand new
ill sell for $150 plus postage
-C
So these "attacks" are being caused by someone? Or bugs/viruses? Combination of both?
Can it be tracked or something?
Not too clued up on this type of thing but if someone needs a gearboxing I'm sure it can be arranged, I have one on standby :)
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
