BTW - switched to a new mobile skin now. Works well.
Also put the skin in the 'Change Theme' drop box so you can go back to it if you switch to full version.
Still cannot use full version via mobile (iPhone)
all good prank. my notifications stil say the same thing. also not able to follow whoretown (bob) or the lulz thread still.
Can you screen shot the notifications? Can't reproduce it anywhere. :(
then this is what i get when i click on said notification.
Im getting the same problem on a few of the threads i am following.
It looks like all of the old threads i was following are good, its the newer ones that i am having trouble with.
Sorry if I've missed it guys, been reading through the latest threads here but haven't seen it mentioned.
What's going in with video embedding? Using my mobile (Android), I can't see embedded videos using either the Full Version or the Mobile Version of the site. Posts containing an embedded video are just big blank empty posts.
quick heads up if it hasn't been reported already, subscribed to a few forums and instead of nbsp tags they get replaced with &#160 tags which shows up in email programs for windows and android.
So on the website it's self it looks fine, however the email version gets a bit annoying to read.
eg. http://www.skylinesaustralia.com/forums/topic/420345-for-sale-clean-out-cheap/#entry6760663
what it actually looks like in mail version:
"hey have few parts that i wanna get rid of been sitting around for
awhile
brand new never used GFB BOV still in box $200 brand new
ill sell for $150 plus postage
-C
So these "attacks" are being caused by someone? Or bugs/viruses? Combination of both?
Can it be tracked or something?
Not too clued up on this type of thing but if someone needs a gearboxing I'm sure it can be arranged, I have one on standby :)
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
