Hi All,
Just curious, has anyone ever installed the pop up OEM sat nav screen (not so concerned with the screen just the actual pop up mechanism and screen casing) in a m35 model that does not have the sat nav as standard (the one that has the mini glovebox instead)? Considering putting the screen in but would like to have it neat and 'stock looking'
If not any suggestions for nice places/methods of mounting a 7" screen?
thanks guys :)
I'm looking at doing something similar. Although I have a double din fascia to go in, I already have a single din Pioneer PRS99 to install and will probably fill the gap with the Defi Din Gauge. For the monitor I am considering the Mimics X2 or a simple touchscreen and mini PC. As the navi buttons won't be needed I was just going to fill the space with a trim piece or something.
Someone in the States has already installed a touch screen in place of the OEM nav screen a few years ago in their Infiniti G35 (essentially the same interior). Dracov's CarPC. Stock Navi replacement DIY. The process would be similar for a Series 1 M35. As for installing the pop-up mechanism in a non-navi Stag, I can't see why (I hope) it can't be done so long as you get all the parts required and can get the little button on top to trigger the monitor to go up and down. As soon as I can get a navi monitor and trim I will be giving this a go anyway.
Just be aware that in Series 2 M35s, the stereo fascia (integrated or double din) is slightly taller (a few mms) on non-navi models. So if you get a navi pop-up screen the trim will overlap. This picture shows the difference - the non-navi is on the right.
This photo shows another idea for installing a screen (I think this is an SAU member's Stagea). If you're handy with fibreglass, this shouldn't be too hard to make. Unless someone knows where to source this item.
Edited by QJQ
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
