Hi All,
Just curious, has anyone ever installed the pop up OEM sat nav screen (not so concerned with the screen just the actual pop up mechanism and screen casing) in a m35 model that does not have the sat nav as standard (the one that has the mini glovebox instead)? Considering putting the screen in but would like to have it neat and 'stock looking'
If not any suggestions for nice places/methods of mounting a 7" screen?
thanks guys :)
I'm looking at doing something similar. Although I have a double din fascia to go in, I already have a single din Pioneer PRS99 to install and will probably fill the gap with the Defi Din Gauge. For the monitor I am considering the Mimics X2 or a simple touchscreen and mini PC. As the navi buttons won't be needed I was just going to fill the space with a trim piece or something.
Someone in the States has already installed a touch screen in place of the OEM nav screen a few years ago in their Infiniti G35 (essentially the same interior). Dracov's CarPC. Stock Navi replacement DIY. The process would be similar for a Series 1 M35. As for installing the pop-up mechanism in a non-navi Stag, I can't see why (I hope) it can't be done so long as you get all the parts required and can get the little button on top to trigger the monitor to go up and down. As soon as I can get a navi monitor and trim I will be giving this a go anyway.
Just be aware that in Series 2 M35s, the stereo fascia (integrated or double din) is slightly taller (a few mms) on non-navi models. So if you get a navi pop-up screen the trim will overlap. This picture shows the difference - the non-navi is on the right.
This photo shows another idea for installing a screen (I think this is an SAU member's Stagea). If you're handy with fibreglass, this shouldn't be too hard to make. Unless someone knows where to source this item.
Edited by QJQ
    • If the tyres were fitted when new, I wouldn't expect much over 5 years of use. Especially if the car lives outside full time.  If the tyres had been stored under ideal conditions and are being purchased new, I'd fit a set of already 5 year old tyres if I only expected to get 1 to 2 years of use out of them.  I've purchased many a set of new (but quite old) tyres from St George Tyres when I just needed some decent rear tyres to drift on.  Here is a pretty crazy example, can't say I've ever bought 11 year old tyres from them before though lol.  https://www.stgeorgetyres.com.au/momo-tyres-245-45-17-outrun-m3-official-product-by-momo-italy.html
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
