hey all. I already have a thread for this in the WTB section but thought I'd put it in the NSW section too since that might make it easier if anyone here has pieces. Mods if this belongs ONLY in the WTB section then feel free to delete the thread.
Basically, got my car, have a few bits and pieces - mainly cosmetics that I want to fix up. Here's the list. Located in Sydney, NSW around Hornsby area so am willing to drive a bit to pick up (would have to be weekends) but otherwise am also willing to pay postage - depends how much it costs.
Have had some offers but still waiting on pics etc.
  • Armrest centre console lid - my hinge is half snapped
  • Need a new rear driver-side speaker mesh cover in the back, the ones that are on the parcel shelf at the back - Haven't checked if this is removable by itself, so if not, may need an entirely new parcel shelf
  • Driver side rain shield - the clear red colour piece of plastic that sits above the door so you can open some window when it's raining...?
  • If anybody has an aftermarket centre dash console - from the 3 gauges downwards to the stereo area then welcome to show me some pics and make me an offer, I don't quite like the material of the stock console.
  • If anybody has nismo indicators at all, let me know too.
  • if you have any headlights sets/bulbs that you want to sell off, also make me an offer.
  • Rear seat covers - make me an offer OR if you have a set of rear seats for sale also let me know.
  • Castor bushes - nolathane etc etc + rack ends. please contact me ASAP
Please PM me or post here if you have something! I always check.
Cheers guys.
The speaker mesh are pretty hard to find! I gave up lol
The weather shield and dash bits can be had in the CF group buys on SAU pretty cheap and easy.
For the castor bushes and rack ends etc look up GKTECH.COM and similar and you will get a good deal, they are whole arms though.
haha Mat, found some guys with a parcel shelf - so may just swap out the entire thing. don't seem to be many group buys going on now...?
i know that my castor bushes and rack ends need replacing but i'm after a quote on how much it'd cost to replace all/most of the suspension system.
Bump + update(s)
  • Driver side rain shield - weather shield. will take offers for both passenger + driver. also do not mind if aftermarket.
  • If anybody has nismo SMOKED indicators at all, let me know too.
  • if you have PROJECTOR headlights sets/bulbs that you want to sell off, also make me an offer.
  • Castor bushes - nolathane etc etc + rack ends please contact me ASAP
  • Stock R34 GTT BOV needed
  • 4 weeks later...
Another update. Items still required.
Bump + update(s)
  • If anybody has nismo SMOKED Front bar indicators at all, let me know too.
Bump + update(s)
You can try my stock BOV if you want, but you have to come get it :P And bring me a 6 pack lol
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
