Big Brake Group Buy #2 - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
Ok sweet - I will update thread over the weekend.
Full money ready once we have 10 people for the next batch. Nothing required until then (I will PM everyone once we get close to 10ppl to remind) :)
How far does the caliper on the 356mm setup protrude perpandicular to the mounting face of the disk? Just trying to work out of these will clear the spokes on my high-offset RPF1's, as I needed an ~8mm spacer to clear my stock GTT brakes.
There was some info on it, in the first thread:
http://www.skylinesaustralia.com/forums/topic/413182-big-brake-group-buy-skyline-silvia-stagea-wrx-evo-all-makesmodels/
Have a read and see if it covers the question, if not post up again and see if we can search for more detail :)
http://www.skylinesa...ll-makesmodels/
Thanks for that Nismoid.. I did see the post towards the end of that thread from Aaron.. Are there technical drawings available of the kits from D2? I really only need two measurements, caliper protrusion from face of disk hub, and radial distance of caliper from center of disk. Sorry for the big ask, I really want to run these wheels without spacers and if I can manage this with a brake upgrade then its win win!
Paul - Had a chance to call past IM yet to see about 380mm?
Everyone else - Updated as below.
Thanks for that r31, ill just get the anodized black 356mm for a r32 Gtr, when would you like the deposit
Added on - Race pad is $150 extra. Ok with that?
Deposit - not required. No money until we get to 10 people, I'll PM everyone once we get to 8 so you can get pennies ready :thumbsup:
I'll put an order in for Anodized Black 356mm fronts with race pads for an r32 gtst, with delivery to Brisbane.
Yep no problems also I live in Sydney
Yep that's no problem.
Hi Guys
D2 got back to me with templates for the 356mm 8 piston fronts. As it says on the doc, it's a guide and can't be used as gospel - ie if you have a bee's dick between the template and the spokes then a real world test fit would obviously be a better option :)
Cheers
Aaron
NI04-7-Model.pdf
NI05-1-7-Model.pdf
NI05-7-Model.pdf
NI06-7-Model.pdf
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
