Big Brake Group Buy #2 - Skyline / Silvia / Stagea / Wrx / Evo / All Makes/models
I'm in for a r33 gtst front kit 356mm, street pad, anodized black, but not 100% sure yet on colour, is that alright to update later if I change my mind on colour?
Listing:
1. geetea-are - 356mm Front only / R32 GTS-t - Race Pad - Anodised Black
2. calcal - 356mm Front only / R32 GTS-t - Race Pad - Anodised Black
3.
4.
5.
6.
7.
Im not sure if it makes a difference but my car is a r32 gt-r not gts
I so want in on this. I'm doing my darndest to find a spare $1800.
One question, and a long shot, I don't suppose any of these kits would fit an X series Falcon? (XA-XC and XD-XF) Also might have a mate keen on a set for a BA XR8 if any of them will fit.
Updated! :)
After thinking a bit more, i am going to pull out of this, as i think its overkill for my setup.
Ok updated.
Only what is on their website is what they have kits for. So it would need to have a new dogleg made up to mount it (and ensure you get the right kit to suit the PCD) and you should then be fine!
will the 356mm Fronts fit on LMGT1 17 inch?
All 356mm kits require 18" wheels mate.
Are D2's any different to ATTKD brake kits?
Also, I have a set of Nismo braided lines, would they be compatible with these brakes? Race pads and rotors are easy to source correct?
And is this group buy at risk of not happening due to numbers?
Cheers
Same stuff essentially.
As the mounting of the kit actually comes with a new arm - they might be ok (just depends on how much spare length you have).
Rotors can be sourced via Import Monster moving forward, and are cheap :)
It'll happen - just needs interest. First one is just about done
G'day Nismoid can u pls put me down for the following setup, cheers:
- Anodized Black 356mm Fronts with Race Pads for an R34 GT-T on the Gold Coast
Also, do you know of & recommend any brake specialist to install these kits around the Goldie &/or Brisbane areas???
Thanks again!
Edited by LoNg_ShaNks
Looks like ill be selling my front and rear brake set and it wont clear my deep dish rims
356mm Front / R32 GT-R - Street Pad - Anodized Black
330mm Rear / R32 GT-R - Street Pad - Anodized Black
pickup only in western sydney, pm me
What sort of time are we looking at for the next round? I would like a purple set for a 32gtr 356mm front and 330 rear with street pads and the handbrake kit to cairns
  • 11 months later...
  • 1 month later...
Definitely, though our pricing has reduced quite a bit anyway due to the stronger AUD since we originally conducted this GB
  • 4 weeks later...
Awesome id be keen on a 356mm front set in black for 33 gts-t. How far off before starting over again aaron?
I'm good to go whenever, not sure if the rules allow me as a business trader to conduct the group buy myself and I know that Ash has far too much on his plate right now
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
