Hey Guys,
My name is Bobby , I am new to SAU forums but no stranger to owning Jap imports etc.
I used to have an R32 (in my avatar) , since then had an S15 and now just drive my ute.
I work with Dohmar and grabbed a non complied 33 late last year, planning on doing some hill climbs, motorkhanas, track days etc.
The paintwork on the car is a bit rough and it was an automatic when I got it, its now manual with short shifter and puck clutch.
Got Marky Marc at ET's to do some exhaust work for us with a screamer and flutes out the back , slowly but surely adding small bolt on's until I can spend more time and money later in the year once I finish working on the house.
I started a blog to generate a bit of interest from friends, family and anybody that wants to donate goodies marketing.
Check out the link if you get bored, I doubt I will get to any interstate events but for the Adelaide guys I look forward to seeing some of you other guys out there in 2013 ! :action-smiley-069:
Cheers
https://www.sau.com.au/forums/topic/417261-newb-in-adelaide/
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
