Brought off ebay from japan front and rear brake caliper overhaul kits primarily to replace the rubber piston boots which cop a caning from heat generated I suspect on track days. Thought there would be no harm replacing the piston seals also as they are probably hardened with age and heat as well.
Only problem is the parts packets are labelled in japanese and I am unsure about the grease sachets included.
The front kit came with one sachet of pink coloured grease. The rear kit with two smaller sachets of pink/orange grease and one white/beige grease.
My question is what exactly is the grease for? I imagine that one is rubber grease for the seals and boots on reassembly but not sure why I have three different types in the two kits. Guesiing that maybe the whit/beige is for the slide pins?
Anyone used these kits before or know which grease is which???????
I have emailed the supplier but so far have not heard back.
https://www.sau.com.au/forums/topic/417280-brake-caliper-overhaul-kits/
In the absence of any replies from supplier or other sources I bit the bullet and did some google research. Brought a tub of penrite red rubber grease from autobahn and some permatex slide pin grease from supercheap and left the supplied unknown sachets unused.
The job wasn't too bad. A bit fiddly reseating the new boots in the caliper cylinders but the seals and slide pin rubbers are dead easy.
For anyone who is interested my caliper seals were in perfect condition. No observable wear or for that matter on the pistons or cylinder bodies. The car has done 87K and quite a few track days/ happy lap sessions etc.
Probably the only lesson to be learnt is go easy on the non brembo brakes on the track. Give them plenty of cool down laps. And if you do perish your dust boots from excessive heat. They are replaceable with the overhaul kits available.
Hi Nate
My manual also said to coat seals and boots. It said to use either rubber grease or brake fluid on the seals. I used rubber grease and would recommend it as seems to allow pistons to go in more easily than just the fuid. The tolerances on caliper to piston are quite small and the grease seemed to be prefered by most mechanics I consulted via google. I just used my fingers to lube all round seal and then push into place in the wheel cylinder housing groove they go in. However the dust boots were a different story, tried using grease as recommended on the inside of the boot but it made it such a slippery mess to then seat the boot in the cylinder and piston grooves that I gave up. Wiped off every thing and fitted boot dry over end of piston. Then put a smear of grease around piston before pushing into caliper cylinder with fingers and seating outer seal in piston groove. I used conmpressed air to carefully push piston back out half way to check boot was properly secured into housing.
Be careful using compressed air as it takes minimal effort to blast piston out of cylinder. Most manuals show operator puting a small wooden block in the pad space to cushion the blow of ejection. I forgot to do this once and tried using my fingers to catch the piston. Almost broke it and took skin off!
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
