SERIES 1 PARTS
rb25det series 1 afm green label great upgrade for rb26 I've got 2
$50 or 80 for both
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$250
r33 gtst front hubs, rotors and brakes good for 5 stud
$200
r33 gtst drive shafts
great condition
$30ea
r33 rear cradle just the cradle
$20
r33 gtst brake master complete non abs
great condition
$30
r33 custom one peice tailshaft
$90
r33 engine crossmember perfect for rb conversions
$50
R33 power steer rack
Great condition
$30
r33 front sway bar
$20
r33 series 1 behind the dash aircon stuff
make a offer
r33 series 1 window trims from door and car the one that always fade
make a offer
r33 overflow bottle
$10
R33 gtst ignition barrel and locks with key
Good condition
$130
R33 gtst side mirrors
$20 each
r33 passenger side gaurd with blinker
maroon
$20
R33 series 1 dash
$30
R33 gtst centre console
Good condition
$20
R33 doors bare
good condition
$20 each
R33 gtst tail lights
Great condition
$20 each
R33 glovebox
$20
R33 boot with aftermarket wing/spoiler looks similiar to standard one lights up skyline
$20
R33 handbrake with full handbrake cable to hubs
$30
R33 passenger window reg motor
$35
R33 passenger window switch
$20
R33 bonnet latch and cable
$30
R33 bonnet latch bracket
$20
r33 boot and fuel flap latch assembly
$20
r33 air con unit/display
$20
R33 complete air con set up with everything!
condenser
compressor
dryer
lines etc
$130
SERIES 2 PARTS
Rb25det series 2 motor from 97 model
Blue painted covers
Complete with Loom and ecu
115000kms
$1250
R33 series 2 auto gearbox has been modified and tricked up not sure exactly but also comes with a trans cooler
$100
Bare rear subframe
$20
rb25det series 2 afm pink label great upgrade for rb26 just need 1 more
$60
hubs
rotors
calipers etc
$250
r33 gtst front hubs, rotors and paint gold brembo brakes look like r34 Gtr but are standard r33 look awesome
$300
r33 series 2 gtst drive shafts
great condition
$40ea
r33 gtst series 2 brake master complete abs
great condition
$50
$50
R33 series 2 power steer rack
Great condition
$30
R33 aftermarket front strut brace
$40
r33 front sway bar
$20
r33 series 2 behind the dash aircon stuff
make a offer
r33 series 2 window trims from door and car the one that always fade
make a offer
r33 gtst series 2 ecu
$60
r33 series 2 gtst engine loom perfect condition
$150
r33 overflow bottle
$15
r33 gtst series 2 front seats
Great condition drivers have minor tear
$50
r33 gtst series 2 door cards front and rear
good condition
$100
r33 series 2 rear bar silver
$40
R33 gtst series 2 ignition barrel and locks with key
Good condition
$130
R33 gtst series 2 side mirror passenger silver
$30
Silver
$30
R33 gtst series 2 centre console
Good condition
$20
R33 series 2 door passenger
good condition
$20
Great condition
$30 each
R33 glovebox
$20
$50
R33 pasenger window reg motor
$35
$20
$50
$40
$30
r33 series 2 air con unit/display
$30
R33 series 2 complete air con set up with everything!
$150
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
i have all the interior plastics for series 1 and 2
Gold Coast can post
0487924497
Hey guys ill be going to Sydney early next week with a car trailer so if you need any parts ill bring them with me or if you know anyone that needs a car transported from Gold Coast to Sydney I can also do that for fuel costs
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
