Looking for a complete dash loom, from the drivers kick panel junction across the dash mounting bar over to the ecu connectors.
Prefer the series 2 loom.
Proce inc postage to Sydney please?
Hey mate, just after a cpl small parts if you have em by any chance..
Rubber Bonnet Stoppers
Window Bracket Stoppers (the little felt bushes that guide the window from inside the door)(the ones that scratch everyones windows!)
cheers
cheers
Hey mate I have the felt bits your talking about drivers and passengers ill have to check for the rubber stoppers what's your mobile and ill get back to you this arvo
Cheers
Cheers
Did you get my message?
Or did we talk and I forgot? lol..
Hey mate, just wondering if you've still got a few things:
- R33 S2 door trims
- R33 steering column plastic surround with the ignition barrel plastic
- R33 drivers side window switch (or does it come with the door trims?)
And if possibly, could I get pics of the door trims as I'm after mint condition ones.
If you're still got any of it, best price posted to Meadows, 5201 SA. Cheers.
  • 7 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
