yeh not many S.1's around.. :rolleyes:
For some reason to do with import regs almost all Australian imports are of turboed Stageas whereas in NZ the big majority are n/a like the Rips car was when he bought it.
Epic build. I can't believe this is all done with stock diffs, driveshaft and suspension. Insane!
I'm not at all surprised that this beast is as stable as it is... that was one of the first things I came to appreciate with these cars after putting the foot into my 260RS the stability under speed and in corners is quite a surprise and a pleasure to drive.
And the series 1 ain't nothing to frown at... I restored mine with new silver trim and grey lenses on the front from Dolphin (original 260RS) part and they look mean as hell from the front. Plus it's all colour coded, I get heaps of looks and positive comments from randoms on the street.
Edited by CruisingFast
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
