Wrong.
Smash camera with bricks, try to inject broken camera in arm, take bricks to tin shack, ride pit bike to cash converters, threaten cashier with mullet, takes munies then die in a stairwell of a heroin overdose.
FYP.
#drinkingattheredcow
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055493
Meh, was working. Couldn't make it. Can post?
man, we just whored this build thread.
How is the transgo shift kit, feel good Matt?
LOL! Gotta fill the thread with something!!
Great, grabs heaps hard, car feels fasts. Has made the car completely different.
Car is almost where I want it, mod wise.
Next on list:
HFC's
Uprev
Maybe V36 Y-pipe because rusty vag pipe in between stainless steel HFC's and cat back exhaust has gaids.
Then finished with grips and "performance" side.
After that will be trying to fix paint, interior, electronics.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055517
Next on list:
HFC's
Uprev
And tighten moar bolts.
It's like the Harbour Bridge.
Sorry for whoring. I'll stop now.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055546
  • 1 month later...
  • 1 month later...
Small update.
A Fenix radiator arrived today :D
I've also purchased, walbro 255 fuel pump, 510CC Power Enterprises injectors and an Uprev cable.
Just need Uprev MAF, Uprev tuner software, LFR6AIX-11 spark plugs and a couple more cooling bits.
Then gotta save for install, fab and tune.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7165360
  • 1 month later...
Oh I haven't updated!!
So the radiator, Scotty's cooling bypass mod and nismo thermostat were installed a couple weeks ago. mad props to PNmad for doing the work while I supervised while swimming in a pool of coolant and trans fluid :D.
Recently been worried about the stag using a bit of oil. I serviced it less than 3 to 4 months ago and on monday I checked my dip stick and spotted it on the half way mark, checked the sump and areas around it for damp and slimy areas but everything was dry.
Just today when I was changing over cam position sensors I noticed the below. Appears my spark plug well has turned into an oil well.
I have come to notice that for every thing I mod/change Rajab f**ks something else. Rajab loves it.
Edited by M35woah
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7205045
Its no big deal, most of the VQ's I see have oil in the plug well. It is insulative so it doesn't affect the spark.
How long since you changed the plugs? If it's been a year or more, I would just suck the oil out with a syringe and small hose. The seals aren't replaceable so you would need to get an entire rocker cover and gasket to fix the weep. Big dorrahs.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7205082
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
