Wrong.
Smash camera with bricks, try to inject broken camera in arm, take bricks to tin shack, ride pit bike to cash converters, threaten cashier with mullet, takes munies then die in a stairwell of a heroin overdose.
FYP.
#drinkingattheredcow
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055493
Meh, was working. Couldn't make it. Can post?
man, we just whored this build thread.
How is the transgo shift kit, feel good Matt?
LOL! Gotta fill the thread with something!!
Great, grabs heaps hard, car feels fasts. Has made the car completely different.
Car is almost where I want it, mod wise.
Next on list:
HFC's
Uprev
Maybe V36 Y-pipe because rusty vag pipe in between stainless steel HFC's and cat back exhaust has gaids.
Then finished with grips and "performance" side.
After that will be trying to fix paint, interior, electronics.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055517
Next on list:
HFC's
Uprev
And tighten moar bolts.
It's like the Harbour Bridge.
Sorry for whoring. I'll stop now.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7055546
  • 1 month later...
  • 1 month later...
Small update.
A Fenix radiator arrived today :D
I've also purchased, walbro 255 fuel pump, 510CC Power Enterprises injectors and an Uprev cable.
Just need Uprev MAF, Uprev tuner software, LFR6AIX-11 spark plugs and a couple more cooling bits.
Then gotta save for install, fab and tune.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7165360
  • 1 month later...
Oh I haven't updated!!
So the radiator, Scotty's cooling bypass mod and nismo thermostat were installed a couple weeks ago. mad props to PNmad for doing the work while I supervised while swimming in a pool of coolant and trans fluid :D.
Recently been worried about the stag using a bit of oil. I serviced it less than 3 to 4 months ago and on monday I checked my dip stick and spotted it on the half way mark, checked the sump and areas around it for damp and slimy areas but everything was dry.
Just today when I was changing over cam position sensors I noticed the below. Appears my spark plug well has turned into an oil well.
I have come to notice that for every thing I mod/change Rajab f**ks something else. Rajab loves it.
Edited by M35woah
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7205045
Its no big deal, most of the VQ's I see have oil in the plug well. It is insulative so it doesn't affect the spark.
How long since you changed the plugs? If it's been a year or more, I would just suck the oil out with a syringe and small hose. The seals aren't replaceable so you would need to get an entire rocker cover and gasket to fix the weep. Big dorrahs.
https://www.sau.com.au/forums/topic/417327-my-pnm35/page/7/#findComment-7205082
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... šŸ˜›
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. šŸ”¹ Initially, he quoted me $3,500 - $4,500. šŸ”¹ First invoice: $5,315 (already above the quote). šŸ”¹ Second invoice: $1,375. šŸ”¹ Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like Iā€™m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! šŸ™ Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
Ɨ
Ɨ
