Slightly Urgent! Are These Mats R32 Gt-R Or Gts/gtst Accessory Items?
Hi all,
I'm looking to 'retire' the original factory mats from my R32 V-Spec because they're in pretty good nick and getting hard to replace. I think they're better kept nice for the odd show or display.
I would rather replace them with genuine Nissan accessory mats because I've kept the car factory stock and in very nice condition. I don't want to use custom mats, and would only buy the black Nismo ones if I had to.
I've found these mats on eBay and don't know if they're accessory mats for the R32 GT-R, accessory mats for the R32 GTS models or originals from the GTS models.
http://www.ebay.com.au/itm/140904076556?redirect=mobile#ht_500wt_922
Can anyone please help to identify them for me?
The text on the badges ("Nissan Genuine Parts") indicates that they are accessory items. Maybe they are universal fit for both GT-R and GTS models? I'm pretty sure that they're not R33 items because that series seemed to have a rectangular plastic heel pad on the driver's mat:
http://www.ebay.com.au/itm/140803615656?redirect=mobile#ht_1574wt_689
Any help would be great! If they are GT-R accessories then I'm keen and need to get in quickly!
Cheers!
Mike
I have a set of Genuine GT-R floor mats for mine from factory. They are the same shape and everything apart from the centre one from the back but a different material so i would say maybe they had an option for what type you wanted? They even have the floor clip holes and the centre back mat.
Edit: inside there is NO difference from a gts-t to a GTR apart from the dash cluster. They will fit both.
Edited by Anfanee
I popped into Japanese Motorsport here in Adelaide and Tyson identified them as R32 GTS or GTS-T mats. He's a GT-R expert and his observation is that they won't fit the GT-R well because the floor pans are different, hence the different shaped rear centre mat.
Oh well, I'll keep on waiting.
The first ones are definately 33 series 2 GTST and the second are r33 GTR, possibly 32
GTR and GTST are different on the drivers mat as the GTR ones have a curved cut out on the left side to allow for the bigger tunnel as per the second link
  • 4 weeks later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
