My 25t seems to be having probs under boost.
Under light boost I don't seem to notice anything. Under load it feels like a blocked carby. I think this may be due to my turbosmart bleed valve. I have searched and people talk about violent jerks, mines not that but it definately stutters under load.
Are these bleed valves fine when properly installed or is this just the trade off in being an el cheapo mexican and buying a turbosmart bleed valve?
Would a GFB bleed valve do the same thing assuming the rest of the setup, hoses etc are ok?
If not how much is an EBC and whats the best? I am thinking of getting a PowerFC in the future should i just hold off and buy the boost cont that comes with that.
Any trouble shooting tips I could use to stop the stutter? Or is this a turbosmart curse?
Advice please
PS did search but didn't find exactly what I'm after.
PPS only mods are below rest car is stock
https://www.sau.com.au/forums/topic/41735-is-it-spiking/
All I have in mine is pull the hoses off the solenoid an replace it with a piece of aluminium pipe with a 7/64 hole through it. Took a little trial and error to get the hole size I needed.
ROCK SOLID 10PSI with less than 1PSI spike occasionally.
That little bit of pipe was a lot cheaper than any bleed valve and is the ultimate stealth installation.
https://www.sau.com.au/forums/topic/41735-is-it-spiking/#findComment-854888
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
