ok, the missu and i have been toying around with the idea of making the move from sydney to QLD.
we dont know where yet.
but it would have to have employment, and hopefully be not far from the car scene.
what reasons can i use to convince us to move?
come on people, throw up those positives!
lets hear them.....
  • Replies 138
Much better traffic for starters. If you are after the most jobs and the biggest car scene then Brisbane would be the best then the GC then Ipswich, although the GC has almost no jobs atm. Winners of 7 origins in a row :whistling:
Just don't move to Mackay unless your a miner, cost of living especially rent is double the price of everywhere else. But i guess coming from Sydney (like me, i'm from Frenchs Forest) then you'd be used to that. Oh and it's humid as all hell up here, sunny coast is definitely where you wanna be mate.
was born in bris, but have have lived in most states in aus, ippy is the worst place iv'e called home accept for canberra. GC hinterland, maroochie coolum, happyrock is my pick, further north and you need a high tolerance to heat and bitties/ stingies
Mike.
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
    • Hagerty posted this yesterday.
