  • Replies 138
My girls gonna be doing her 5 year veterinary doctorate at Gatton starting this year so I'm going to have to move to Toowoomba before years end. How hard is is to find work there and whats the rent situation like?
All depends on what type of work your looking for? As for renting, I am unsure but when friends have been looking for places to rent they always seem to find a place fairly easy.
Con:
Cane toads.
Cane toads, that's a pro, very good practice for your golf swing
Avoid Noosa, it's full of hippy bohemian people... Freaks me out lol
noosa is just fine, all the hippies live at eumundi and cooroy. they come into noosaville to shop a bit, but if you're over noosa heads way, or further down the coast at coolum or peregian then you are close to the beach (quieter beaches than noosa), close to noosa as well as maroochydore/alex heads/mooloolabah, etc. it's a pretty good spot to be only 10 or 20 mins from everywhere. and because all the people who want to try and pretend they have money want to live around noosa heads, etc, then the prices are pretty decent too. not that much traffic either. brisbane traffic sucks (like all major city traffic), but the sunny coast is much better.
Yes Brisbane traffic sucks...still a lot better than Sydney though. You need to rank our priorities Luke, the sunny coast is a lovely place to live but has a much smaller car scene and is quite a way away from tracks and drags. Brisbane is not as nice but has a much bigger scene and is a lot closer to tracks. Either way the Skyline scene up here is a fair bit smaller than what you have in Sydney.
Even then, it all depends on where you live and where you work when in Brisbane. For example, my commute has about 4 traffic lights, a bit of highway driving and taeks 15 minutes. Not bad at all.
takes me 45 to 50 mins to drive 63kms from gympie to noosa for work everyday....... i'd much prefer to do that than sit in traffic in brissy for 45 mins and only go half that distance.
BUT, you have to live in Gimpy
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
