Hi there, sorry this isn't a forsale post.
Look I am trying to find the username of a member on here who I bought some red GTR rocker covers off of, but have unfortunately not received them yet.
I accidentally lost his number and have spent hours on SAU for sale section trying to find his original post.
It would have been posted between the 15-20th of December 2012.
It was for red GTR rocker covers, he was asking about $200 for them. From memory he was either from Sydney or Melbourne.
I never pm'd him on sau as he had his number posted up on the add.
These are the rocker covers in question.
If the original poster or anybody knows about these covers or who may have been selling them, could you please send me a message on 0450313126
I am not at all accusing him of anything, just wanted an update as the christmas break may have slowed things down, just without his number I am left with no way to get in contact with him.
Thankyou, Sheldon
https://www.sau.com.au/forums/topic/417358-gtr-rocker-cover-info/
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
