stiffshifter Posted January 9, 2013 Share Posted January 9, 2013 Hi all, do s1 Stagea rsfours have hydraulic tappets or solid ones? Thanks Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/ Share on other sites More sharing options...
wolverine Posted January 9, 2013 Share Posted January 9, 2013 hydraulic lifters in S1. Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6699287 Share on other sites More sharing options...
pipster11 Posted January 9, 2013 Share Posted January 9, 2013 confirming what wolverine said s1 stagea motors are the same spec as a s2 r33 s2 stagea = r34 Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6699326 Share on other sites More sharing options...
stiffshifter Posted January 9, 2013 Author Share Posted January 9, 2013 thanks guys, been told different things, but was sure they were hydraulic. Anyone know how to cure them tapping, did oil and filter change today but not driven much since. Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6699335 Share on other sites More sharing options...
pipster11 Posted January 9, 2013 Share Posted January 9, 2013 what weight are you running? 10w40 would be the go, Gulf western oils are pretty detergent heavy so running some of that at 5000km intervals should eventually free it up otherwise you can do what i did to my 31 4 litres of cheapy GW 20w50 (~$13) 2 x Nulon engine oil flush Dump current oil (save it if you want and put it back in after) Insert cheap oil + both oil flush bottles Run for 5 mins at idle, do not drive it!!! lift the revs to 2-3000 rpm for 20-30 seconds idle for 5 mins lift the revs etc... do it so its running for around 20 mins dump the flushing oil, change the filter, put new/previous oil back in party Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6699521 Share on other sites More sharing options...
stiffshifter Posted January 12, 2013 Author Share Posted January 12, 2013 Right tried everything still tapping, should i replace them? any suggestions,or should i upgrade anything while i'm taking bits off? What would you guys recommend? Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6704019 Share on other sites More sharing options...
GTR260 Posted January 12, 2013 Share Posted January 12, 2013 U sure it is not ur injectors making the noise? Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6704137 Share on other sites More sharing options...
wolverine Posted January 13, 2013 Share Posted January 13, 2013 You need to diagnose the issue accurately before you pull out lifters and clean them. Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6704394 Share on other sites More sharing options...
stiffshifter Posted January 19, 2013 Author Share Posted January 19, 2013 Quick update, was the tappets, took it into the garage and they put some heavy duty flush thru, then new oil, filter and treatment went in, amazing the difference it has made. Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6714006 Share on other sites More sharing options...
wolverine Posted January 20, 2013 Share Posted January 20, 2013 I am glad you fixed it without pulling them out. Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6714170 Share on other sites More sharing options...
stiffshifter Posted January 20, 2013 Author Share Posted January 20, 2013 yeah me too, it's amazing how much the whole engine has quietened down. The stuff they use is made by a company called Forte, not sure if it's just a UK product but highly recommend it. Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6714883 Share on other sites More sharing options...
pipster11 Posted January 20, 2013 Share Posted January 20, 2013 Nulon make a tappet quieting product The retail version is different to the one supplied to mechanics tho, if the 31 needs it I go to an ultra tune and ask them to get a bottle in for me, usually works out at about $10 anyway but the bottle says "not for retail sale" or something like that Glad to hear you got it sorted tho Link to comment https://www.sau.com.au/forums/topic/417381-s1-tappets/#findComment-6714997 Share on other sites More sharing options...
