this thread makes my head hurt.
OP, you're approaching this from entirely the wrong angle.
You choose the wheels first and then the width of those wheels dictates the width of the tyre you run. The profile you run isn't a choice, it's a mathematic result that you have to follow in order to keep your VDC and speedo in check.
To say you're researching to buy wheels based on which tyre size is most readily available and well priced is a waste of time. I understand you want to buy a nice grippy tyre, but seriously, at your budget of $1000 your only option will be second hand wheels with tyres fitted, and they'll be 18's at best.
My advice, save another $1k - and then make the decision between buying something new but replica like varrstoen's or rota's and then spend 800 on tyres - or buying something jap brand, second hand with used tyres (of which you'll have no choice in anyway) and then buy better tyres when you can afford it. You'll be much happier.
Very rarely does a truly pleasing outcome result from compromise. And at $1000 budget, compromise is all you can afford. (don't mean to sound harsh, but seriously, 4 good 18" tyres are going to cost you close to $1000 as it is.)
Thanks SmokeyC34. This thread however, is not about me persay. Its a general question aimed to get some direction for newbies to the modding world.
Knowledge can't replace experience.. and that's what I'm looking for, advice from the experienced.
Don't get me wrong. Thanks for all the comments guys. Its been good.. but.. I'll like to keep it away from my situation.. (don't link the threads)
I know the budget of $1000 is a laugh, I came up with the amount for 2 reasons.. one.. I was asked many times what my budget was and two, found a couple of ebay post for 18" OEM Infinity wheels for that much or less... so I thought, lets throw this hypothetical amount into the discussion and see what comes up. Of course.. the tyres on those sets was either balding or cheapies... which I still think would be better than the cheapies on my 20"s..
I'm trying to achieve, one thing. What's the best tyre/wheel combination .. vs common size tyres for the best bang for the buck.
I'm taking the analytical approach to researching this topic! Lol! No.. I'm not an analyst!
If everyone agrees with your comment "To say you're researching to buy wheels based on which tyre size is most readily available and well priced is a waste of time" ... I'll go with your advice.
sigh. I still don't understand the point of your question - but i'll answer it anyway.
ok - stick with 18's.
buy in 8 inch widths, then you can buy 245/45/18 which is what commodores run - so plenty of tyres available domestically.
(incidentally this would net you pretty close to the exact same setup as the OEM 18s (18x7.5 18x8).)
So why don't you snag a set of OEM's - get them powdercoated black or gunmetal grey - throw some stick rubber on them and you'll have a tidy setup for under $1500.
OEM wheels pretty much cannot be beat. They're cheap, they're easy to come by, and they're strong as all hell. They fit without fouling anything, they're legal under all insurance policies, and the car was designed to work with them.
Edited by SMOKEYC34
I think this ^ answer was what the OP was after.
If wheel 'fashion' is not at the top of your priority list, then buying rims that run a more common tyre (hence better choice & price) is a smart thing to do. Unless you are a wheel whore, you will always buy more tyres than rims, & I've never seen a rim that adds more to handing & ride then a well chosen tyre.
Slightly off topic, but does anyone have a ballpark figure on powder-coating a set of 4 rims? and also, another strange question, do they / can they powder-coat the inside (ie where the tyre covers) as well?
No idea about powder coating cost but I painted my 18" OEMs just before Xmas - used the same silver colour as the car but darkened it a bit, 3 coats of paint & 3 coats of clear. I had the outside beads broken so it was easier to mask up, cleaned with wax & grease remover, sanded out most of the scratches & filled the bigger ones with body filler, then painted. Total cost was SFA, but we already had the paint & clear coat. You can buy wheel paint & clear in rattle cans as well. They came up fine - probably not quite as nice as powder coating but "they're just rims".
Thanks Mat. Your idea about power coating the OEMs is brilliant! I might do that! I think for short term .. I might go back to my OEM 17's for the time being.. Bucketing down in Sydney yesterday.. Went into a roundabout slowly ! Yes Slowly with family onboard and my front tyres lost grip, understeered but got it back.. but not comfortable with it. Did it 2x! Tyres tyres tyres..
powdercoat (approx $100 per rim), paint yourself (maybe $100 in materials and a weekend), or even cheaper/easier would be to plastidip the (probably need 6 cans - so $160 in materials)
If you're not up with Plastidip, it's a rubberised paint that you spray on and it sets as a bonded layer over your rims (in this case) - but they beauty is you can just peel it off if you don't like it after a while!
http://www.plastidip.net.au
So depending on your choise, that's approx $200 to bring your rims up to scratch which leaves uou $800 for tyres which will get you some pretty nice tyres in 17 inch size.
Something like these would be nice:
http://www.ebay.com.au/itm/2-X-New-235-45-17-BRIDGESTONE-POTENZA-ADRENLIN-RE002-TYRES-/290841551679?pt=AU_Car_Parts_Accessories&hash=item43b781e33f
or for something a bit more agressive, could give the nitto's a go (don't expect them to last forever though, treadwear is something like 200 - meaning they're sticky, but soft)
http://www.ebay.com.au/itm/2-X-New-235-45-17-NITTO-INVO-PERFORMANCE-TYRES-HOLDEN-FORD-NISSAN-GTR-MERCEDES-/230909264927?pt=AU_Car_Parts_Accessories&hash=item35c343c41f
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
