Up for sale 2 sets of 4-point Takata harnesses including the mounting parts to secure them into the car. Hardly used, mint. 300 dollars each plus shipping or pick-up from Adelaide.
Hi, Lou
Will have first dip at the pair subject to verification of date of manufacture and " genuine Takata ? ) please send pics with all tags to 0433878905
Do you have receipt and condition of harness
For clarifications! one harness for the driver side and another one can be used for the passenger side, not two for driver and another two for passanger.
After a SAU member brought to my intention in regards of harnesses validaty after the year stated on the harness, I decided to do more research to clarify what I know w/ respect to the Cams Rules & Regulations and FIA interpretation. In addition, I've contacted two professional national track participants, and they also confirmed what I am going to share w/ you shortly. Furthermore, I surfacely touched the ADRPG rules regarding the harnesses requirements on the tracks. At the end of the day, all sites I visited refer back to the Cams rules.
Briefly, Takata has stated on the harnesses I have "Not Valid after 2010." Based on the Cams rules, the harnesses are still good for use in any events (except of international ones) until 31st of Dec 2015 but after being inspected by event organisers/inpectors. The inspectors usually look for worn harnesses, damaged latches, etc... As long as the harnesses are not torn, not damaged, have working latches, all stitches there, etc..., the harnesses are good to go for the event.
Even after 31st of Dec 2015, you still can use them outside of the track for your show car if you like.
I am attaching a couple of documents to show you what I found in Cams and also from other sites. In these documents, I've circled and underlined key points of the matter. You can also look into it as well if interested and let me know if I missed anything.
As I said before, the harnesses were hardly used, not brand new, genuine, and they do not show any signs of wear, tear, damage, etc... If you want to buy a brand-new genuine Takata harnesses (dated 2015 and above), expect to spend around $600 dollars or more for each set.
Hope this clarifies it.
Thanks,
Lou
Got tired of accepting offers and then people do not bother responding. If you are not up to it, please do not waste my time. Thanks.
Should have an accurate description of what is being recieved. Not waiting
for an offer to be made then adding "by the way these wont be included".
Also after checking progress of recent sales, accuracy of other item descriptions (misleading information on Recaro seats) and previous sales history Im no longer confident in transferring funds. I cant be the only trader with these views, evidence being the difficulty you are having selling items and constant questions of authenticity.
Please do not waste my time. Thanks
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
