Custom Er34 / Bnr34 Hid Headlights
EvoXenoN
 Share
G'day ppl,
Thought Id start this thread to show you a custom set of ER34/BNR34 HID HLs that I'm going to be finishing hopefully this weekend.
The custom projector HLs that I've seen on the net so far look like Sh!t tbh...
Here are the specs & parts list for the HLs:
* Full Satin Black finish using VHT Prime Coat SP305. Produces an effortless smooth finish
* Honda Euro (aka: TSX) HID projectors sourced by Jesse Streeter off Yahoo Auctions Japan
* 2.5" TSX-R clear lenses from TheRetrofofitSource . com
* 3" OEM E46 shrouds with the XENON logo. Sourced from eBay
Let the pix begin:
RHS HL pulled apart. High beam reflector masked up to keep dust free:
OEM E46 shroud will be retrofitted to sit inside the HID reflector:
Pic of both XENON logos. Unfortunately, the R34 one has to go:
The reflector is attached to the HL housing at 3 points. I took these pics so I could see the position on the adjustment screw for when it comes time to removing the reflector off the HL.
Here's a pic of the Honda Euro projector disassembled. The cut off shield is masked and ready for paint:
Close up:
Projector cutoff shield after 2 coats of VHT Red paint:
Crappy OEM fresnel lense vs Aftermarket TSX-R clear lense. You can see "swirling" effect on the lense. This is designed to blur the output. The TSX-Rs will sharpen it all up:
Blurry OEM output:
Output with the TSX-R clear lense:
OEM output close up:
TSX-R output close up:
Making way for the projector
Trial fittment:
Quick mock up of the reflector / projector / shroud:
Stay tuned for more updates
  • Replies 57
Wow you are extremely game, chopping up a set of 34 headlights, but am definitely keen to se how it turns out!
Not a cheap exercise if you get it wrong, thumbs up for going to the effort :thumbsup:
Yeah I'm "extremely game" and I've been known to "get it wrong" most of the time :)
You have no idea shinobi_s14 on what a "ballsy move" I'm doing to your HLs. Ask the last guy how impressed he was when I was "slicing and dicing" his Kia HLs
Check out my username, "EvoXenoN" for google pix of all the headlights that I've stuffed up HERE.. So funny!!!
^ he's game cause they're my HL's haha. But nah Steve knows what he's doing. He's work is nothing short of perfect, can't wait til they're done
You've got balls to let someone chop it up! but keen to see the end result, I really want projectors on mine as well. might yet Steven to do it too if hes offering services :)
UPDATE #2
RHS HL fitted to car and ready for the projector to be rotationally aligned before getting permanently fixed in
Centre of the projector lense is measured to the ground. The figure in this case is 590mm
I didn't have a long stretch of wall to test and align the output so I improvised. I stacked up a few orange containers and stuck A4 pieces of paper in the middle. The light will shine somewhere in the middle of the paper across all three stacks. They've been placed about 5m from the car
Close up of the A4 paper showing a strip of black electrical tape stuck on. The top edge of the electrical tape is measured at 565mm from the ground. This is 25mm lower than the height of the middle of the projector to the ground. The low beam output will be aligned to this height.
Here's a pic showing the Honda Euro projector in the low beam reflector
Close up of one of the corner shows the application of JB Weld to help bond the projector to the reflector. I did this on 2 other areas and waited about 20min for the bond to harden
OEM reflectors removed from the HL housing then more JB Weld applied around the projector.
Projector body and lense masked for paint
Blacked out
XENON logo masked on the OEM E46 shroud and ready for about 3 coats of white paint. It takes me about 1hr to mask one shroud... That's 2hrs right there.. Lots of tiny pieces of masking tape
Parker housing masked as the surrounding area will be blacked out
Everything fitted up minus the lenses. They were quite yellow from oxidation that they wouldn't show any detail of the work I've done
Stay tuned for when the HLs are polished + install pix...
^^ cheers...
And ppl thought I had balls to hack into R34 HLs...... Niggah pls!!!!
It is pretty ballsy to be honest, I didn't have enough nuts to do it but you look like you know what you're doing. You have PM :)
 Share
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back to our newest location for our Sunday morning coffee catchups! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 10th November Meet Location: Baybreeze Cafe - 2 Wellington Street, Sans Souci (entry via Plimsoll Street) Meet Time: Meet at 8:00am Map: https://tinyurl.com/sausundaysession-baybreeze This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
