G'day ppl,
Thought Id start this thread to show you a custom set of ER34/BNR34 HID HLs that I'm going to be finishing hopefully this weekend.
The custom projector HLs that I've seen on the net so far look like Sh!t tbh...
Here are the specs & parts list for the HLs:
* Full Satin Black finish using VHT Prime Coat SP305. Produces an effortless smooth finish
* Honda Euro (aka: TSX) HID projectors sourced by Jesse Streeter off Yahoo Auctions Japan
* 2.5" TSX-R clear lenses from TheRetrofofitSource . com
* 3" OEM E46 shrouds with the XENON logo. Sourced from eBay
Let the pix begin:
RHS HL pulled apart. High beam reflector masked up to keep dust free:
OEM E46 shroud will be retrofitted to sit inside the HID reflector:
Pic of both XENON logos. Unfortunately, the R34 one has to go:
The reflector is attached to the HL housing at 3 points. I took these pics so I could see the position on the adjustment screw for when it comes time to removing the reflector off the HL.
Here's a pic of the Honda Euro projector disassembled. The cut off shield is masked and ready for paint:
Close up:
Projector cutoff shield after 2 coats of VHT Red paint:
Crappy OEM fresnel lense vs Aftermarket TSX-R clear lense. You can see "swirling" effect on the lense. This is designed to blur the output. The TSX-Rs will sharpen it all up:
Blurry OEM output:
Output with the TSX-R clear lense:
OEM output close up:
TSX-R output close up:
Making way for the projector
Trial fittment:
Quick mock up of the reflector / projector / shroud:
Stay tuned for more updates
https://www.sau.com.au/forums/topic/417403-custom-er34-bnr34-hid-headlights/
  • Replies 57
Wow you are extremely game, chopping up a set of 34 headlights, but am definitely keen to se how it turns out!
Not a cheap exercise if you get it wrong, thumbs up for going to the effort :thumbsup:
Yeah I'm "extremely game" and I've been known to "get it wrong" most of the time :)
You have no idea shinobi_s14 on what a "ballsy move" I'm doing to your HLs. Ask the last guy how impressed he was when I was "slicing and dicing" his Kia HLs
Check out my username, "EvoXenoN" for google pix of all the headlights that I've stuffed up HERE.. So funny!!!
^ he's game cause they're my HL's haha. But nah Steve knows what he's doing. He's work is nothing short of perfect, can't wait til they're done
You've got balls to let someone chop it up! but keen to see the end result, I really want projectors on mine as well. might yet Steven to do it too if hes offering services :)
UPDATE #2
RHS HL fitted to car and ready for the projector to be rotationally aligned before getting permanently fixed in
Centre of the projector lense is measured to the ground. The figure in this case is 590mm
I didn't have a long stretch of wall to test and align the output so I improvised. I stacked up a few orange containers and stuck A4 pieces of paper in the middle. The light will shine somewhere in the middle of the paper across all three stacks. They've been placed about 5m from the car
Close up of the A4 paper showing a strip of black electrical tape stuck on. The top edge of the electrical tape is measured at 565mm from the ground. This is 25mm lower than the height of the middle of the projector to the ground. The low beam output will be aligned to this height.
Here's a pic showing the Honda Euro projector in the low beam reflector
Close up of one of the corner shows the application of JB Weld to help bond the projector to the reflector. I did this on 2 other areas and waited about 20min for the bond to harden
OEM reflectors removed from the HL housing then more JB Weld applied around the projector.
Projector body and lense masked for paint
Blacked out
XENON logo masked on the OEM E46 shroud and ready for about 3 coats of white paint. It takes me about 1hr to mask one shroud... That's 2hrs right there.. Lots of tiny pieces of masking tape
Parker housing masked as the surrounding area will be blacked out
Everything fitted up minus the lenses. They were quite yellow from oxidation that they wouldn't show any detail of the work I've done
Stay tuned for when the HLs are polished + install pix...
^^ cheers...
And ppl thought I had balls to hack into R34 HLs...... Niggah pls!!!!
It is pretty ballsy to be honest, I didn't have enough nuts to do it but you look like you know what you're doing. You have PM :)
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
