Hi headlight guru.
I am looking to do this to my r32 gtst skyline later on during the year and was wondering if I could ask you a few questions.
Would i get the same stuff or would I need some specific items?
I want to make it dual high beam and low beam if possible.
also would getting the kit from that website be better?
any help or recommendations is greatly appreciated.
Thanks
I'm doing the retrofit to my R32 lights. I am assuming you have projectors lights (which most R32s have).
Get the FX-R projectors (RHS, 3" lens) from TRS. They go on with not much effort, don't need to make brackets up. Just need to tap one existing hole and drill + tap another, and they go straight onto the adjusters. Also order a pair of AMP > D2S straight adaptors (this). Yes you can find ones in China for $5 but you have to wait 1 month for them to come, whereas the TRS stuff usually turns up within two weeks.
Get D2S HID kit, like this one. 4300K temperature is best. I found that recently, the cheap HID 4300K bulbs aren't 4300K but more yellow. Good to invest in something better I suppose. I will find out very soon if the bulbs in that kit are good.
For dual high beam, I wired up an 'anti-flasher' relay wiring for the headlights using three relays and diodes. It allows you to flash high beams while still retaining the lowbeam (so essentially they act as two separate circuits, so the lows don't turn off when you high beam). Might be a bit more complicated approach, but then you can always use something from TRS.
Butyl rubber glue stuff you can source locally.
  • Replies 57
Get the FX-R projectors (RHS, 3" lens) from TRS. They go on with not much effort, don't need to make brackets up. Just need to tap one existing hole and drill + tap another, and they go straight onto the adjusters. Also order a pair of AMP > D2S straight adaptors (this). Yes you can find ones in China for $5 but you have to wait 1+ month for them to come, whereas the TRS stuff usually turns up within two weeks.
Get a D2S HID kit. 4300K temperature is best, although I found that the cheap HID 4300K bulbs are more yellow. Good to invest in something better I suppose. Get 'F3 Start Bright' ballasts and your choice of bulb in 5,000K. Don't bother with 4,300K unless it's Philips/Osram). Don't bother with 'Hyluxtek' as I did back-to-back testing and the F3 Start Bright ones are a lot better and not noisy.
Whoops stuffed the edit up. Ignore my previous posts. Don't bother with the HID kit I listed, get F3 Fast Bright kit and optionally a better bulb.
Edited by niZmO_Man
Hi Nizmo man,
Thank you so much for the very informative information. I will definitely be doing this very soon.
Did you find the 5000k HID kit bulb a bit too yellow or just right?
Also, I might get something from TRS for the dual high beam
Thanks heaps once again.
Hi Nizmo man,
5000k HID isn't going to be yellow at all. If anything it will be a bit blue. 4000k is white, anything above starts going blue, then 10k starts going purple.
6000k is my preference for light output vs aesthetics.
5000K will be white white, as seen on Merc S-class cars.
Whether 4300K is white enough is personal preference... And your parker lights lol.
I haven't used 5000K as of yet. I always get 4300K, but I got a pair of 6000K from Mars performance in my R31. I find then a tad too blue for my liking. I think 5000K is good for looks vs. light, but as stated 4300K is best (daylight) if you want to actually see. The Mars performance bulb is actually very good. Back to back testing they easily surpass the el cheapo bulbs and even the TRS ones.
I'm currently tracking down a pair of 5000K, so will provide some pictures once I do find some.
Surprise surprise, projectors makes a difference after all! 4300K is white and I'm very happy with them. I'm not going to bother with 5000K bulbs.
Ordered a pair of Philips 85122+ bulbs, lets see the difference compared to the Chinese stuff.
  • 4 months later...
Very interested I can your results
Sorry man, forgot about this thread.
The Philips bulb is a bit yellow-er (probably 4200K) but they apparently colour shift as they get older. The output is no different but the spread is better (e.g. cutoff is cleaner).
But cant you just change to a phillips d2r 6000k bulb but use the same ballast? Or doesnt work that way? So would you recommend phillip or bosch? I cant seem to find it online :( can anyone link me please? xD
Edited by Wongy
You can always throw a cheapie HID kit and it will get you going/will keep you happy.
Guessing you want something like this:
http://www.theretrofitsource.com/product_info.php?products_id=147
Doesn't have to be Bosch or Philips.
I'm sure someone with R34 factory HID lights can tell you what ballasts it has.
  • 3 weeks later...
I think I found the stock ballast, quick question, if I need to put the d2r adapter on will I need to take off front bumper to acess the ballasts under the headlights? Or can I access it by taking off the washer bottle and the intake on the other side, thanks guys :)
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
