Damaged R34 Gt-T
For Sale is my R34 GT-T which unfortunately had some bad luck and met a wall.
This car has been very well maintained and ran/runs flawlessly. It has been serviced every 5000Km and have had no major issues with it.
The car is stock minus a 3" Exhaust turbo back, JVC speakers and DVD headunit.
It has brand new coilpacks and an Excedy Heavy Duty Clutch which has done 6000Km.
The car is still registered until 23 Jan and has not been classified as damaged or as a write off.
The main damage has been sustained to the front right hand side of the vehicle with some less significant damage on the right rear. The car will still drive although it has no radiator or intercooler as both were damaged beyond repair. The rear bar has only minor damage, a picture will be included later if required. Included is a front bar in reasonably good condition.
I was planning to repair the vehicle but do not have time due to work commitments.
Located in Frankston, Vic
Contact: Joel 0437 944 223
Price: $6000 Ono
Edited by sirjb
  • 3 weeks later...
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
