hmmm well you could do this:
for performance increases:
- 3" exhaust: dump/front/cat/cat-back/muffler
- high-flow panel filter in original airbox
- cold air intake
- turbo: many options from higfh-flow rb25 turbo to something like a 2530 or whatever
- FMIC
- re-chip standard ECU or get a PowerFC
- EBC + boost increase
for reliability increases:
- gtr fuel pump + fuel pressure regulator
- oil cooler
- trannie cooler
that should just about do it!
please correct me if anythign i said was inaccurate...
cheers,
Waz.
A well tuned rb20 with a 2530 could make 220rwkw, but as already said, they seem to be making around 200rwkw. It depends how far you want to go really, a tune can make or break a combination so it is quite important. Im pretty sure that alot of those RB20's making 200kw off of a 2530 are running stock ecu (correct me if im wrong about this) so a PFC should be able to extract more power out of it.
I dont think the prob is so much the cost, but the ones i have seen have T25 flanges, but i expect they are available with T3.
If you look at the light tune drift cars in Japan with SR20s etc, a good percentage of them use Apexi, Tomei, Trust turbos, then if you look outside of Japan you have Turbonetics, Garret so many choices... but it depends on your budget
A 2nd hand 2530 for $1500 represents good value, but if you have $2500-3000 to spend on a new turbo then dont forget to look around at what other manufacturers make.
where using a t3 t4 garret turbo and where making 230rwkw from our rb20. we have got forgies in oursa but that only for reliability, but my cuz has got wolf, FMIC, turbo and exausht and he is making 200rwkw so for more punch i would say mabye even a set of cams?
cyas
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
