hi guys,
can someone recommend an air con specialist in the Sydney area?
having issues with my car's aircon that is currently playing up.
It will go cold, then hot then cold (when moving) and then stay hot for awhile (even when moving).
If i try again later, it might get cold for a brief period and then start blowing hot air again when i come to a stop.
it is hit and miss and sometimes will not get cold for a long period (20-30mins) and with sydneys heat wave this week, i was dying in the car.
had the aircon checked at local mechanics and there is definitely gas left and is not leaking.
so after recommendations for a air con specialist to have a look and determine what the exact root of the problem is, as it is very frustrating.
Thanks in advance...
  • Like 1
https://www.sau.com.au/forums/topic/417515-air-con-specialists-in-sydney/
There used to be a group buy for Frosty Auto Air in Bass Hill. He does good work. I've also used Hahn Automotive in Alexandria, but that was just a re-gas after i changed the condensor. Also seemed good.
Also dont forget the auxilliary fan diode mod in the DIY section. It should help with the going hot when stationary issue.
Hey guys,
Call Pete from Pulse Auto Electrics. His shop is located in castle hill and has heaps if experience with aircon and also imports.
Pete 0407008651
Cheers
I will be giving Pete a call.. i need my a/c compressor repaired along with some custom plumbing made up..
Pete should be able to help me out you reckon Jonny?
He should be able to mate, just give him a call and have a chat to him
Pulse regassed my aircon, after finding a leak in one of the lines and after pulling half the car apart to get to it.
Excellent service and a good price for the amount of mucking around to get the pipe out which needed to be welded.
+1
BE AWARE WHEN BUILDING DUMP PIPES TO ALLOW ROOM TO GET AIRCON REGASSING FITTING ON.
  • 3 weeks later...
  • 1 year later...
On this topic is there any info for a recommended aircon place near lower north shore? I think mine needs re-gassing, but would good to get hychill if anyone can recommend a place? I have done a bit of searching online but can't tell who has it without calling each joint.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
