Was out driving my r33 S1 today when i noticed alittle miss under load every now and then. Thinking it was a typical coil pack issue i just took it easy.
It started to get worse and is clearly not a igntion issue, it apears to be fuel. Everytime i try to give it gas it hesitates but it will still idle?
End result was a tow truck ride home, and just to add insult to injury when i got it home it still runs and drives fine?!
This is a heavily modified rb25det but this has got me beat. Its never let me down before but reminds me of trying to drive it with a intercooler pipe blown off. (if that makes any sence)
Pump is still working, ecu tells me that the duty cycle on the injectors is normal. I did fuel up 30 minutes before i left but does not have the characteristics of dirty fuel...Somthing is failing when it gets hot, but what?!
Good brain teaser for the crew..
On a foot note, the only person that stoped to help me push the car off the road was a fellow skyline driver! Full respect mate.
https://www.sau.com.au/forums/topic/417535-mystery-fuel-issue/
My money is vapour lock
All symptoms sound like it
Depending in mods
Fuel boils in the lines or filter and the engine dies and wont restart for a while on hot days or lots or stop start driving
Next time it happens remove fuel cap and see if it starts that drops off over pressure in the tank
any leaks or water in the fuel does it
So does e85 fuel , ethanol and super hot days don't go together
Highly doubtful its vapour lock. Not with 40+psi behind it. Increasing the pressure raises the boiling point of liquids. And the pressure would push any vapourised fuel through the system quick smart.
narrowed it down this arvo, definatly fuel pump! Its got a bosch 040 in tank in it and over the past few days i had been thinking to myself that it seemed to be louder than normal??...took it for a drive today until it started playing up and i can hear the pump reving up and down all unstable.
So out it comes tomorrow!
Case closed,, thanks for the input guys
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
