Wreaking R34 Non Turbo
Front end smash, Not written off, rego has been cancelled
1998 R34 GT Non turbo
Some parts may not be available as i will be keeping for my own car
Just to name a few prices
Rear bar $200
Side skirts $200
Front seats $200
Rear seats $100
Lhs headlight $100
Lhs guard $100
Center console $50
Cluster 100ks or so $100
And heaps more will take some time to get the full list so will list as i go
Can post smaller parts at buyers expense, Sorry cannot post large items unless organized by buyer
Located in Sydenham/Delahey 3037 VIC
Preferred if contact me via sms or leave a post below/pm me and ill reply back asap
0411 655 097
Edited by Johnie
https://www.sau.com.au/forums/topic/417549-wreaking-r34-non-turbo/
  • Replies 52
Rear bar $200
Bootlid $200
Complete doors minus door trims/side mirrors $200 each
Door trims $100 pair
Diff $200
Side Mirrors $200 pair
Side skirts $200 pair
Front seats $200
Rear seats $100
Lhs headlight $100
Headlight loom $20
Lhs guard $100
Carpet $50
Parcel shelf $100
Center console $50
Glovebox $50
Overflow bottle $20
Interor/boot trims from $20
Fuel flap $50
Interor light $20
Rear view mirror $20
Auto cluster 1xxxxx $80
Cluster surround $20
Aircon vents $20
Sun visors $20 pair
Ashtray $20
Fuse box cover $20
Climate control $20 missing 1 button
Seat belts $100 the lot or $50 each
Odd parts from $20
Wat condition is the centre console in?
Center console is in good nick just the lids hinges are not the best (gets stuck opening and closing)
and no hand brake cover
Pms replied to
Cool. Do you also have the gear stick trim and the facure trims?
No gear stick or facure trims, car was auto,
PM sent
shotgun ashtray + weather shields if available
Pm replied
Lucky i kept the stock tailights as i just coped a defect on my r34 today so my smoked tail lights are up for sale
$300 the pair
Edited by Johnie
Im looking for the below bits from the boot.
- The black plastic trim where the latch is,
- The rear window washer motor plastic cover &
- The trim that goes around the boot
How much posted to 4152?
Yeah got all, Not sure how to post it though its kind of big, so ill prefer for large items to be picked up
Ok what about the black plastic trim where the latch is & the rear window washer motor plastic cover?
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
