  • Replies 52
Sold so far
Ashtray
Rad support mounts
Prices on the main things of what i have available
Rb25de neo complete engine 100ks $1000
Smoked Tail lights $250 pair
Rear bar (no reverse lights) $200
Bootlid $200
Complete doors minus door trims/side mirrors $200 each
Door trims $100 pair
Diff $200
Side Mirrors $200 pair
Side skirts $100 pair (1 has crack)
Front seats $200
Rear seats $100
Lhs headlight $100
LHS headlight loom $20
Lhs guard $100
Carpet $50
Parcel shelf $100
Center console (hinge no good) $50
Glovebox $50
Overflow bottle $20
Interior/boot trims from $20
Fuel flap $50
Interior light $20
Rear view mirror $20
Auto cluster 1xxxxx $80
Aircon vents $20
Sun visors $20 pair
Fuse box cover $20
Climate control $20 missing 1 button
Stereo surround bracket $20
Seat belts $100 the lot or $50 each
Odd parts from $20
Edited by Johnie
Sold so far
Ashtray
Rad support mounts
Reverse lights
Center aircon vent
Rb25de neo complete engine with ecu, auto 100ks loom is damaged $1000
Bootlid $200
Diff $200
Front seats $200
Rear seats $100
Lhs headlight $100
Lhs guard $100
Carpet $50
Parcel shelf $100
Glovebox $50
Overflow bottle $20
Fuel flap $50
Interior light $20
Sun visors $20 pair
Fuse box cover $20
Airbox snorkel $50
Bottom half of the airbox $50
Odd parts from $20
Edited by Johnie
right hand door handle? pick up only live down the road
Sorry not separating from door, will be selling complete
got rhs front splash guard?
Yes i do, however its currently stuck with the wheel. $20 if i can manage to get it off.
darn, how about left side door window motor?
darn, how about left side door window motor? also the two rear rims?
Sorry guys selling the door complete $200 each
No wheels available
hey you got cat back exhaust?
No cat back exhaust available at the moment :(
Bump,
2.5/3inch Nismo catback exhaust will be available for $500 once removed from the car, just cant seem to remove the tight bolts atm
Front and rear seats $300 perfect condition
Smoked tailights $250
Edited by Johnie
R34 non turbo neo cover $50
R34/R33 Stock muffler $50
R34 glovebox $50
R34 2.5-3inch nismo catback $500
R34 airbox snockel $50
R34 LHS Xenon Headlight broken brackets $150
R34 Center console $50
R34 Steering column $50
R34 Climate control/headunit bracket $50
R34 middle console thingy on the top right of photo $50
Edited by Johnie
Engine, loom and ecu??
Yes it still available,, cannot be shown running however its a complete engine
Minus afm, air intake and pod filter as they were damaged
Asking price is $1000 negotiable after inspection
Will go cheaper if buyer can remove the engine as i will need to call my mate to get his help to remove the engine using his engine crane and tools, oh and his grinding skills to cut off the damaged rad support and its currently very close to the engine.
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
