Food - What Is Good, What Is Ok, And What Is Really Bad For Us
now to forget about calories and hit the macro targets.
How heavy are you?
Doesn't seem like much
So if I've done it correctly, 150g of carbs a day, 127g protein a day and 50g of fat a day.
I weigh 58 kg
What are you trying to achieve? At that body weight if you are worried about body fat very high chances that you have very low lean body mass
I'm trying to achieve visible muscle definition, especially core area
She's a chick.
no matter what anyone says, she's not going to be happy till she loses a bit of fat/weight.
This...
She wants the skinny guy six pack.
You just need a bit more muscle, it'll do the same thing, but at a more healthy weight.
  • Like 1
How many years have you been training?
What are your lifts like?
Your diet is ridiculous..
You more then likely have very little lean mass.
What you desire requires discipline and alot of hardwork in the kitchen/gym
I've been going to the gym for 10 years, but have only been following a weights program for the last 2 years. I only started bench in December and it's currently at 30kg, incline is at 25kg and decline is at 35kg (max) squats and dead lifts I'm starting in a couple of weeks. My lean muscle mass is 44kg and I weigh 58 kg
What do you suggest to make my diet less ridiculous ? I've come on here to receive suggestions. I've done the iifym calculations and will start using that to help me.
You dont need incline decline and flat bench.
Do you have a photo of your current physique you can post?
I post off a phone so I appolagise if it was someone else. Whos diet I have in mind.
What have you been doing at the gym for 10 years? Aerobics? Cardio ect or have you done some resistance work in the past?
There's a photo on page 1 in the fitness selfies thread of me 4 months ago, only difference is ab definition has diminished.
Yes, the last 10 years of gym work has been comprised of aerobics, cardio machine work (bike, treadmill, cross trainer, rower) boxing and yoga. I haven't really done any resistance work until a couple of years ago.
Post it here or pm it to me. Its hard to navigate around on my phone.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
