Food - What Is Good, What Is Ok, And What Is Really Bad For Us
now to forget about calories and hit the macro targets.
How heavy are you?
Doesn't seem like much
So if I've done it correctly, 150g of carbs a day, 127g protein a day and 50g of fat a day.
I weigh 58 kg
What are you trying to achieve? At that body weight if you are worried about body fat very high chances that you have very low lean body mass
I'm trying to achieve visible muscle definition, especially core area
She's a chick.
no matter what anyone says, she's not going to be happy till she loses a bit of fat/weight.
This...
She wants the skinny guy six pack.
You just need a bit more muscle, it'll do the same thing, but at a more healthy weight.
  • Like 1
How many years have you been training?
What are your lifts like?
Your diet is ridiculous..
You more then likely have very little lean mass.
What you desire requires discipline and alot of hardwork in the kitchen/gym
I've been going to the gym for 10 years, but have only been following a weights program for the last 2 years. I only started bench in December and it's currently at 30kg, incline is at 25kg and decline is at 35kg (max) squats and dead lifts I'm starting in a couple of weeks. My lean muscle mass is 44kg and I weigh 58 kg
What do you suggest to make my diet less ridiculous ? I've come on here to receive suggestions. I've done the iifym calculations and will start using that to help me.
You dont need incline decline and flat bench.
Do you have a photo of your current physique you can post?
I post off a phone so I appolagise if it was someone else. Whos diet I have in mind.
What have you been doing at the gym for 10 years? Aerobics? Cardio ect or have you done some resistance work in the past?
There's a photo on page 1 in the fitness selfies thread of me 4 months ago, only difference is ab definition has diminished.
Yes, the last 10 years of gym work has been comprised of aerobics, cardio machine work (bike, treadmill, cross trainer, rower) boxing and yoga. I haven't really done any resistance work until a couple of years ago.
Post it here or pm it to me. Its hard to navigate around on my phone.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
