deansr33 Posted January 13, 2013 Share Posted January 13, 2013 Hey guys I have a r33 and she has a after market blow off valve which i love but it screams out defect me... Im looking for the stock blow off valve i found a r34 bov will that fit my r33? and in future im looking at running 12 psi will it still be ok ? Cheers Dean Link to comment https://www.sau.com.au/forums/topic/417600-stock-r34-blow-off-valve/ Share on other sites More sharing options...
Got a Pulsar Posted January 13, 2013 Share Posted January 13, 2013 I believe the R34 and R33 BOVs are the same and 12psi will be fine. Good choice to return to a stocker Link to comment https://www.sau.com.au/forums/topic/417600-stock-r34-blow-off-valve/#findComment-6704205 Share on other sites More sharing options...
mad082 Posted January 13, 2013 Share Posted January 13, 2013 the stock bov should be fine for 12psi. you have to remember that it isn't just the spring pressure holding it shut against the pressure in the cooler pipe. it has a boost feed so the pressure on each side of the bov is the same. so while it is just the spring holding the bov shut, it isn't just the spring vs 12psi. it is the spring + 12psi vs 12psi. if you get what i mean, lol. Link to comment https://www.sau.com.au/forums/topic/417600-stock-r34-blow-off-valve/#findComment-6704215 Share on other sites More sharing options...
deansr33 Posted January 13, 2013 Author Share Posted January 13, 2013 thanks for your help guys Link to comment https://www.sau.com.au/forums/topic/417600-stock-r34-blow-off-valve/#findComment-6704442 Share on other sites More sharing options...
